DMVPN isakmp sa not dropping
Hey guys,
what is the configuration syntax so that after the router detects no traffic coming from the peer it kills the tunnel.
This is currently what I have, but it doesn't seem to be working.
crypto isakmp policy 5
encr 3des
authentication pre-share
group 2
crypto isakmp key abc123 address 0.0.0.0 0.0.0.0
crypto isakmp keepalive 20
Re: DMVPN isakmp sa not dropping
Try to change "crypto isakmp keepalive 20" to:
crypto isakmp keepalive 20 periodic
John
HTH, John *** Please rate all useful posts ***
Still not killing the tunnel after the 20 seconds ... we're into a minute now.
Also tried "on-demand" with the same result.
Hall of Fame Super Silver
Hello Brent,
you can influence the duration of dynamic spoke to spoke tunnels.
Spoke to Hub tunnels stay up because the routing protocol hellos are always running.
So you can see an effect only when you ping from lan to lan between two spokes.
This can trigger the dynamic tunnel
After the end of the ping this will be turned down.
Hope to help
Giuseppe
362
