05-28-2009 08:15 PM - edited 03-04-2019 04:55 AM
I have just completed my WAN Link failover using route-map and NAT works perfectly fine. The problem I now face is when the primary link goes down and backup is active, the DMVPN tunnel that uses the primary link also goes down which is a problem for our VPN connection to a DMVPN spoke sites.
Is there a way to dynamically get the tunnel to switch to the backup link interface?
Below is the config on the HUB router:
crypto isakmp policy 10
hash md5
authentication pre-share
crypto isakmp key abc123 address 0.0.0.0 0.0.0.0
crypto ipsec transform-set strong esp-3des esp-md5-hmac
crypto ipsec profile 123abc
set security-association lifetime seconds 120
set transform-set strong
interface Loopback0
description PRIMARY LOOPBACK
ip address x.x.x.1 255.255.255.255
interface Loopback1
description BACKUp LOOPBACK
ip address y.y.y.1 255.255.255.255
interface Tunnel0
description DMVPN_HUB
ip address 172.31.4.1 255.255.255.0
no ip redirects
ip mtu 1440
ip nhrp authentication abc123
ip nhrp map multicast dynamic
ip nhrp network-id 1
no clns route-cache
tunnel source Loopback0
tunnel mode gre multipoint
tunnel key 12345
tunnel protection ipsec profile 123abc
interface GigabitEthernet0/0
description PRIMARY WAN LINK
bandwidth 2048
ip address X.X.X.1 255.255.255.252
ip accounting output-packets
ip nat outside
ip virtual-reassembly
ip policy route-map NAT-to-ISP1
no ip mroute-cache
load-interval 30
duplex full
speed 100
media-type rj45
no negotiation auto
no cdp enable
interface GigabitEthernet0/1
description LINK TO SWITCH STACK
no ip address
no ip mroute-cache
load-interval 30
duplex full
speed 100
media-type rj45
negotiation auto
interface GigabitEthernet0/1.500
description SECONDARY WAN LINK
encapsulation dot1Q 500
ip address Y.Y.Y.1 255.255.255.252
ip nat outside
ip policy route-map NAT-to-ISP2
no snmp trap link-status
ip route 0.0.0.0 0.0.0.0 X.X.X.2 name DEFAULT-ROUTE-ISP
ip route 0.0.0.0 0.0.0.0 Y.Y.Y.2 200 name SECONDARY-DEFAULT-ROUTE-ISP
ip route 10.30.4.0 255.255.252.0 172.31.4.2 name 10-ADDRESS-RANGES
ip nat pool bkc x.x.x.252 x.x.x.254 netmask 255.255.255.0
ip nat inside source route-map NAT-to-ISP1 pool bkc overload
ip nat inside source route-map NAT-to-ISP2 interface GigabitEthernet0/1.500 overload
route-map NAT-to-ISP2 permit 10
match ip address NAT_ACL
match interface GigabitEthernet0/1.500
route-map NAT-to-ISP1 permit 10
match interface GigabitEthernet0/0
Network 10.30.4.0 255.255.252.0 via 172.31.4.2 DMVPN spoke end is what I want to reach during the failed primary link to be also routed via backup link.
Solved! Go to Solution.
06-03-2009 05:52 AM
The spoke need a static NHRP entry mapping the hub's tunnel address to the hub's NBMA address. It also needs to send multicast traffic to the hub.
int tun1
ip nhrp map 172.31.4.1
int tun2
ip nhrp map 172.16.1.1
Here is a complete example:
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a008014bcd7.shtml
Laurent.
05-29-2009 07:26 AM
A better solution is to add a backup DMVPN hub in the same physical location as the primary. This will give you the failover that you are looking for. The cost of the route on the spoke will be dependant on the bandwith command on each tunnel Attached is a PDF file describing the installation.
Cheers,
Sam
05-29-2009 01:38 PM
I think it's not working because your tunnel source IP address (loopback 0) is part of ISP1 public range. This address can't be reached via ISP2.
The solution, as already explained in the previous post, is to have two tunnels T1 and T2. T1 is using a source address from ISP1 and T2 a source address from ISP2.
On each remote site, you add a new tunnel pointing to T2 and play with the IGP running inside the tunnel to decide which one is the primary path.
Laurent.
05-31-2009 03:49 PM
Thanks guys for the reply, I'll check out the document now.
Also, we are not running IGP at the moment cause our network right now only consist of 2 sites (hub and spoke) but we are expecting to grow to a max of 5 in a couple of years hence why we decided to use static routing. Per spoke sites, we will only have 10.x.x.x/23 and no other routes.
05-31-2009 05:22 PM
BTW, the doco states multiple HUBs as well as the post above. In my case I only have 1x HUB but with 2x Internet links (2x ISPs). Any other solution I can use?
06-01-2009 05:35 AM
In your case, you need one HUB with two tunnel interfaces (one routed per ISP) and you need an IGP inside the tunnels or you will not be able to detect the HUB lost his primary link.
If you want to keep one tunnel interface, you need both links pointed to the same ISP.
Laurent.
06-01-2009 06:11 PM
Hi laaubert,
Thanks, I will try your solution and let you know.
So far I have EIGRP running on the one DMVPN tunnel1 (Hub/Spoke). I will have to create another DMVPN tunnel2 on both Hub/Spoke and apply the same EIGRP AS.
Let me know if I have miss anything.
Peter
06-02-2009 04:17 PM
I may have missed something on my config. Exactly the same as posted above but with 2x DMVPN tunnel on both hub and spoke to the one physical router. I'm also running 1 EIGRP AS on both tunnels.
show ip nhrp
outputs shows incomplete on the backup tunnel.
HUB
interface Tunnel0
description DMVPN_HUB_PRIMARY
bandwidth 1000
no ip redirects
ip mtu 1440
no ip next-hop-self eigrp 100
ip nhrp authentication s3rvc0rp
ip nhrp holdtime 300
no ip split-horizon eigrp 100
no clns route-cache
tunnel source GigabitEthernet0/0
tunnel key 25052412
tunnel protection ipsec profile cisco
interface Tunnel1
description TUNNEL BACKUP
ip address 172.16.1.1 255.255.255.0
bandwidth 1000
no ip redirects
ip mtu 1440
ip nhrp authentication (private)
ip nhrp network-id 2
no clns route-cache
tunnel source GigabitEthernet0/1.500
tunnel key 91178
router eigrp 100
network 10.30.0.0 0.0.0.255
network 10.30.2.0 0.0.0.255
network 172.31.4.0 0.0.0.255
network 172.16.1.0 0.0.0.255
no auto-summary
neighbor 172.31.4.2 Tunnel0
neighbor 172.16.1.2 Tunnel1
SPOKE
interface Tunnel1
description DMVPN_SPOKE_PRIMARY
bandwidth 1000
ip address 172.31.4.2 255.255.255.0
no ip redirects
ip mtu 1440
ip nhrp map 172.31.4.1 (private)
ip nhrp nhs 172.31.4.1
ip nhrp registration no-unique
tunnel key 25052412
tunnel protection ipsec profile (private)
interface Tunnel2
ip address 172.16.1.2 255.255.255.0
bandwidth 1000
no ip redirects
ip mtu 1440
ip nhrp map 172.16.1.1 (private)
ip nhrp nhs 172.16.1.1
tunnel key 91178
router eigrp 100
network 10.30.4.0 0.0.0.255
network 10.30.6.0 0.0.0.255
no auto-summary
neighbor 172.31.4.1 Tunnel1
neighbor 172.16.1.1 Tunnel2
Any ideas?
06-03-2009 05:52 AM
int tun1
int tun2
Laurent.
06-03-2009 03:38 PM
Thanks Laurent, that works now.
Cheers.
Peter
06-03-2009 09:24 PM
Attached Network diagram and config for both HUB/SPOKE routers.
Traffic from SPOKE to HUB goes via the Primary Link marked in red which is what i want. But if traffic from SPOKE to the MPLS network, it takes the backup path marked in green. This is while the Primary Link at the HUB is still active.
It's not a big problem cause I know I can still get to my servers at all 3 networks and also make a VOIP call as well. DMVPN is only use for management traffic and VOIP.
I tried removing the 2x GLOBAL-10-ADDRESS-RANGES static routes on the SPOKE router and adding network 10.0.0.0 on the HUB under router EIGRP 100 so HUB will send 10.0.0.0 network to SPOKE during update but that didn't work.
I've also covered setting bandwidth and delay on the tunnel interface for EIGRP metric calculations as per attached config.
Any ideas?
06-03-2009 09:26 PM
06-04-2009 07:05 AM
1- From your spoke configuration, you configured two equal static routes, so CEF is load-balancing the traffic per flow and the secondary tunnel will be chosen for half of your source/destination couples
2- What you want to do is right but you need the redistribute static (plus the metrics settings) command under EIGRP instead of the network statement because the hub used a static route to join 10.0.0.0/16.
The network statement allows you to activate EIGRP on an interface to establish an adjacency.
Laurent.
06-04-2009 08:48 PM
Hi Laurent,
All is sorted. Many thanks for your technical advise.
HUB:
router eigrp 100
redistribute static
no auto-summary
SPOKE:
show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is ISP IP ADDRESS to network 0.0.0.0
D EX 10.0.0.0/8 [170/23311872] via 172.31.4.1, 00:15:20, Tunnel1
C 10.30.4.0/24 is directly connected, GigabitEthernet0/1.998
C 10.30.6.0/24 is directly connected, GigabitEthernet0/1.900
D 10.30.0.0/24 [90/13635840] via 172.31.4.1, 00:15:20, Tunnel1
D 10.30.2.0/24 [90/13635840] via 172.31.4.1, 00:15:20, Tunnel1
S* 0.0.0.0/0 [1/0] via ISP IP ADDRESS
06-14-2009 07:50 PM
After intensive tests of the two links fail-over, so far it is what we want. Backup will activate once the primary link is down.
The problem now is if the primary does go down but on a Layer 3 level, the router will still see this as physical UP, protocol UP. The config applied does not work if this is the case.
Is there an alternate to fixing this?
