DMVPN - Ping fails on LAN to LAN
Hi Experts - Seeking your help to understand why I am not able to ping the HUB LAN IP address from Spoke LAN IP address in a DMVPN setup. It is a new installation I am trying to achieve.
1. Ping successful when doing from spoke to Hub Tunnel IP (ping <hub-Tunnel IP address>)
2. Ping fails when doing from spoke to Hub Tunnel IP using source Interface as LAN IP add (ping <hub-Tunnel IP address> source <fa 0/0)
3. Ping fails when doing from spoke to Hub fa 0/0  using source Interface as LAN IP add (ping <hub-Tunnel IP address> source <fa 0/0)
What is the general reason for this. The output from Router below. Can you help me please. Thanks in advance
regards / SAIRAM
debug
HUB#
*Mar  1 03:02:45.107: NHRP: MACADDR: if_in null netid-in 0 if_out Tunnel0 netid-out 1
*Mar  1 03:02:45.107: NHRP: Checking for delayed event 0.0.0.0/192.168.2.1 on list (Tunnel0).
*Mar  1 03:02:45.107: NHRP: No node found.
Config
HUB#
interface Tunnel0
 ip address 172.16.1.1 255.255.255.0
 no ip redirects
 ip nhrp map multicast dynamic
 ip nhrp network-id 1
 tunnel source 127.11.100.1
 tunnel mode gre multipoint
end
interface FastEthernet0/0
 ip address 152.141.1.85 255.255.255.0
ip route 192.168.2.0 255.255.255.0 Tunnel0
SPOKE#
interface Tunnel1
 ip address 172.16.1.2 255.255.255.0
 no ip redirects
 ip nhrp map 172.16.1.1 63.11.124.5
 ip nhrp nhs 172.16.1.1
 tunnel source 208.11.121.3
end
ip route 152.141.0.0 255.255.0.0 Tunnel1
 ip address 192.168.2.1 255.255.255.0
  • WAN Routing and Switching
I noted when I am configuring
I noted when I am configuring the spoke LAN IP address statically in NHRP, I am able to ping from Spoke LAN to Hub LAN.
ip nhrp map <Spoke LAN IP address> <Spoke Tunnel IP address>
But how to make it using Dynamically learn?
regards / SAIRAM
What was the resolution ?
436
