DMVPN question
I'm not really sure if this is the right place to ask but here goes.
I'v setup a small 1 hub 2 spoke DMVPN network.
on the spokes however I'm not seeing the routing table populate with the other spokes internal network. When they ping the others internal network there is no "tunnel" created between the two spokes, that is I do a "sh cry isa sa" and the only peer is the hub. Is this what I should be seeing?
Hall of Fame Super Silver
Re: DMVPN question
Hello Brent,
if you are using EIGRP over the mGRE tunnel you need to configure on hub
int tuxx
no ip eigrp ASN next-hop-self
so that a spoke can see the LAn of other spoke with the original next-hop and this allows to create dynamic spoke to spoke tunnel for lan to lan traffic
Hope to help
Giuseppe
Re: DMVPN question
Yes I've done that. Here is the hub t10 config
interface Tunnel10
ip address 172.30.0.1 255.255.255.0
no ip redirects
ip mtu 1400
no ip next-hop-self eigrp 100
ip nhrp authentication abc123
ip nhrp map multicast dynamic
ip nhrp network-id 200
ip virtual-reassembly
ip tcp adjust-mss 1360
no ip split-horizon eigrp 100
delay 1000
tunnel source FastEthernet4
tunnel mode gre multipoint
tunnel key 7712
tunnel protection ipsec profile NMMHUBDMVPN
Re: DMVPN question
Hello Brent,
on spoke1 you should see LAN of spoke2 with nexthop different from 172.30.0.1
Is it so ?
To trigger the dynamic spoke to spoke you need to do an extended ping with source the local lan ip address of spoke1 and destination the local lan ip address of spoke2
Hope to help
Giuseppe
Re: DMVPN question
ok .. so here is the deal
If I put in static routes from spoke1 to spoke2(and vice versa) going out the tunel10 then this seems to work. So it must be a EIGRP thing. I've put in the "no ip next-hop-self eigrp (as)" command and I still need the static routes.
Has anyone seen this before?
Re: DMVPN question
Hello Brent,
you may need to use a different IOS image on hub router it looks like something is wrong with EIGRP
Hope to help
Giuseppe
Re: DMVPN question
I removed both static routes on the spokes and now the EIGRP portion seems to be working fine. I've added a 3rd spoke and it has the same problem. Seems that static routes somehow reset the EIGRP? Is there a way to stop and restart eigrp?
Re: DMVPN question
Hello Brent,
verify also the state of nhrp because to resolve the private ip address in the MGRE IP subnet the spokes need to ask to the nhrp server (the hub router)
Only after nhrp server answers they can build the dynamic spoke to spoke tunnel.
this is part of config for a spoke
ip nhrp authentication cisco123
ip nhrp map 192.168.1.1 209.168.202.225
ip nhrp map multicast 209.168.202.225
ip nhrp network-id 1
ip nhrp nhs 192.168.1.1
the key commands are
to give the spoke the capability to query the nhrp server
To verify NHRP activity do:
r3725#sh ip nhrp traffic
Tunnel91
Sent: Total 1373
1 Resolution Request 0 Resolution Reply 1371 Registration Request
0 Registration Reply 1 Purge Request 0 Purge Reply
0 Error Indication
Rcvd: Total 4
0 Resolution Request 1 Resolution Reply 0 Registration Request
2 Registration Reply 0 Purge Request 1 Purge Reply
0 Error Indication
Tunnel100
Sent: Total 94
0 Resolution Request 12 Resolution Reply 0 Registration Request
82 Registration Reply 0 Purge Request 0 Purge Reply
0 Error Indication
Rcvd: Total 94
12 Resolution Request 0 Resolution Reply 82 Registration Request
0 Registration Reply 0 Purge Request 0 Purge Reply
0 Error Indication
r3725#
Hope to help
Giuseppe
Re: DMVPN question
it was working beautifully for a while so I decided to simulate a spoke with going down. I chose spoke 2
Now I get this
*Oct 9 21:30:49.971: %CRYPTO-4-RECVD_PKT_INV_SPI: decaps: rec'd IPSEC packet has invalid spi for destaddr=66.38.235.1, prot=50, spi=0x965D5160(2522698080), srcaddr=192.168.0.1
*Oct 9 21:31:19.675: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 100: Neighbor 172.30.0.20 (Tunnel10) is down: holding time expired
*Oct 9 21:31:47.095: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 100: Neighbor 172.30.0.20 (Tunnel10) is up: new adjacency
*Oct 9 21:31:50.915: %CRYPTO-4-RECVD_PKT_INV_SPI: decaps: rec'd IPSEC packet has invalid spi for destaddr=66.38.235.1, prot=50, spi=0x965D5160(2522698080), srcaddr=192.168.0.1
*Oct 9 21:32:51.367: %CRYPTO-4-RECVD_PKT_INV_SPI: decaps: rec'd IPSEC packet has invalid spi for destaddr=66.38.235.1, prot=50, spi=0x965D5160(2522698080), srcaddr=192.168.0.1
*Oct 9 21:33:52.115: %CRYPTO-4-RECVD_PKT_INV_SPI: decaps: rec'd IPSEC packet has invalid spi for destaddr=66.38.235.1, prot=50, spi=0xBB68DF69(3144212329), srcaddr=60.0.0.1
*Oct 9 21:34:30.995: %CRYPTO-4-IKMP_NO_SA: IKE message from 60.0.0.1 has no SA and is not an initialization offer
and spoke2 is no longer participating in the DMVPN
Re: DMVPN question
Hello Brent,
this becomes an IPSec trouble :
try to clear the spoke2 SA on the hub router
Hope to help
Giuseppe
Re: DMVPN question
Seems to me that EIGRP is being really flaky here ... can someone suggest a better routing protocol for a DMVPN network. This will be distributed to about 400 spoke sites so a flaky routing protocol makes me nervous.
Re: DMVPN question
Hello Brent,
OSPF is another possible choice that doesn't need tricks about split-horizon and next-hop-self.
I would try with OSPF, or better using iBGP with the hub(s) as BGP route-reflector it should scale to 400 spokes
Hope to help
Giuseppe
Re: DMVPN question
Is there also a command to set so that if spoke1 goes down then spoke2 two will detect that no traffic is passing and will immediately clear its crypto session?
Re: DMVPN question
Fixed this!!
So I just had to add the
Crypto isakmp keepalive seconds 40(i used 40) on-demand
option and now by the time the router creating the traffic comes up the listening spoke has killed the tunnel at his end.
Thanks for all your help!
Re: DMVPN question
Hello Brent,
I was missing this part of the problem I had thought a keealive mechanism was needed but I thought only of GRE keepalive but not sure it can be used with multipoint GRE and GRE is carried inside IPSec so cannot be the solution here.
well done !
Best Regards
Giuseppe
1543
