Community Member
dmvpn routing issue
@ spoke, I have a tunnel interface and two eigrp peers (primary hub and backup hub)
We installed the backup hub recently..
The dmvpn hub routers AD is tweaked to prefer eigrp external over internal routes
When the MPLS link of remote site 2 goes down, primary and secondary hub injects the prefix into the data centers..
The layer 3 switch has a distance command set toward the respective dmvpn hubs to tweak the AD greater than 170..this way when MPLS route with AD 170 (eEIGRP) is reappeared the dc layer 3 switch will accept it in their routing table.
we have a problem with the failover\failback as we inject the same prefix at two points into the data center..
On dmvpn spoke, is there a way I can form neighbhosrhip only with primary hub and with seconday only when primary is down?
Vinayak
Regards Vinayak
dmvpn routing issue
I think the only way to do it is by using EEM script that will trigger in event of neighborship down with primary router and will add the neighbor statement for backup peer in eigrp process
When the neighborship with primary comes back up it will remove the neighbor statement for backup peer.
Community Member
dmvpn routing issue
will nhs cluster help me in this scenario?
Vinayak
Regards Vinayak
141
