Community Member
DMVPN Traceroute hits hub then spoke !!
Hi Folk , Greetings ..
I have followed the lab posted underhttps://supportforums.cisco.com/docs/DOC-29434 exactly bit by bit and also illustrated below for brevity , but the problem when I do traceroute from one spoke to another spoke , then traffic reaches hub then go to destination spoke I don't see any direct communication from spoke to spoke . I'm wondoring whether if it must not reach the hub and must go directly from spoke to spoke which I want to achieve ....
HUB Configuration ..
interface Tunnel0
bandwidth 10000
ip address 10.1.1.1 255.255.255.0
no ip redirects
ip mtu 1400
ip hold-time eigrp 1 35
no ip next-hop-self eigrp 1
ip nhrp map multicast dynamic
ip nhrp network-id 1
ip nhrp holdtime 360
ip nhrp cache non-authoritative
ip nhrp shortcut
ip nhrp redirect
ip tcp adjust-mss 1360
no ip split-horizon eigrp 1
tunnel source FastEthernet0/0
tunnel mode gre multipoint
tunnel protection ipsec profile DMVPN
All spokes configuration
interface Tunnel0
bandwidth 10000
ip address 10.1.1.xx  255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp map 10.1.1.1 192.168.1.100
ip nhrp map multicast 192.168.1.100
ip nhrp nhs 10.1.1.1
ip nhrp shortcut
ip nhrp redirect
Any help will be highly appreciated ..
1 ACCEPTED SOLUTION
Re: DMVPN Traceroute hits hub then spoke !!
Can the external interfaces of the spokes (not the tunnel interfaces) communicate with each other directly? The external interfaces must be able to establish the IPSec peer with each other for multicast DMVPN to work.
Community Member
Thank you Jeff for posting . Issue has been resolved after adding static routes pointing to each physical external interface ( not the tunnel ) on all spoke routers as below . Indeed my problem that I followed above document exactly and the same was't mentioned any routes should be pointed towards external interfaces .
R2
ip route 192.168.3.3 255.255.255.255 192.168.2.1
ip route 192.168.4.4 255.255.255.255 192.168.2.1
R3
ip route 192.168.2.2 255.255.255.255 192.168.3.1
ip route 192.168.4.4 255.255.255.255 192.168.3.1
R4
ip route 192.168.2.2 255.255.255.255 192.168.4.1
ip route 192.168.3.3 255.255.255.255 192.168.4.1
I'm glad you got it worked out.
734
