DMZ/Forwarding Cisco 3745
jwood1650
I have a Cisco 3745 that is my internet router, I have a domain that directs the web address to the WAN IP address...Can I set up my 3745 to forward incoming connections to my server?  If so, what commands to I need to issue?
Thanks.
jwood1650
Sorry....forgot to add the running config:
3745-Internet#show run
Building configuration...
Current configuration : 2292 bytes
version 12.4
service timestamps debug uptime
service timestamps log uptime
hostname 3745-Internet
boot-start-marker
boot system flash:
boot-end-marker
no logging buffered
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
memory-size iomem 25
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.2.1 192.168.2.150
ip dhcp pool HOME-Network
   network 192.168.2.0 255.255.255.0
   default-router 192.168.2.1
   dns-server 8.8.8.8 8.8.4.4 192.168.2.127 192.168.2.128
ip domain name www.jkkcc.com
ip name-server 192.168.2.127
parameter-map type regex sdm-regex-nonascii
pattern [^\x00-\x80]
username woodjl1650 privilege 15 password 0 henry999
archive
log config
  hidekeys
interface FastEthernet0/0
description $FW_OUTSIDE$
ip address dhcp
ip nat outside
ip virtual-reassembly
ip route-cache flow
duplex auto
speed auto
interface Serial0/0
description $FW_INSIDE$
ip address 10.0.1.9 255.255.255.252
ip nat inside
interface FastEthernet0/1
ip address 192.168.2.1 255.255.255.0
ip nat inside
ip route-cache flow
duplex auto
speed auto
interface Serial0/1
ip address 10.0.1.5 255.255.255.252
ip nat inside
clock rate 2000000
router eigrp 1
network 10.0.0.0
network 192.168.0.0
network 192.168.2.0
no auto-summary
ip http server
ip http authentication local
no ip http secure-server
ip nat inside source list 15 interface FastEthernet0/0 overload
ip nat inside source static tcp 192.168.2.128 80 interface FastEthernet0/0 80
ip nat inside source static tcp 192.168.2.128 25 interface FastEthernet0/0 25
access-list 15 permit 192.168.2.0 0.0.0.255
access-list 15 permit 192.168.3.0 0.0.0.255
access-list 15 permit 10.0.1.4 0.0.0.3
access-list 15 permit 10.0.1.8 0.0.0.3
access-list 15 permit 192.168.1.0 0.0.0.255
snmp-server community public RO
snmp-server community private RW
snmp-server enable traps tty
control-plane
line con 0
line aux 0
line vty 0 4
privilege level 15
transport input telnet
webvpn cef
end
3745-Internet#
no ip nat inside source static tcp 192.168.2.128 80 interface FastEthernet0/0 80
ip nat inside source static tcp 192.168.2.128 80 interface FastEthernet0/0 8100
or you can leave the original command but disable http server on router or you can also configure server to listen on a different port and do a static PAT to this port.
Regards.
Alain
I did the first option you provided and I still get the SDM login for the router....so I did the no ip http server, and tried again to got page error...I should get routed to my server 192.168.2.128 correct?
Here is my current config:
version 12.4
boot-start-marker
boot system flash:
boot-end-marker
no logging buffered
aaa new-model
ip cef
archive
log config
  hidekeys
ip address dhcp
ip nat outside
ip route-cache flow
duplex auto
speed auto
interface Serial0/0
ip nat inside
ip nat inside
ip route-cache flow
duplex auto
speed auto
interface Serial0/1
ip nat inside
clock rate 2000000
router eigrp 1
network 10.0.0.0
network 192.168.0.0
network 192.168.2.0
no auto-summary
no ip http server
control-plane
line con 0
line aux 0
line vty 0 4
privilege level 15
webvpn cef
end
3745-Internet#
