Webcast-Catalyst9k
DMZ
Hi is it recommended to have a DMZ Vlan? What I mean is, if I have a switch on the outside interface of a pix and a switch on the DMZ interface can I just use unused ports on the outside switch i.e. create a VLAN with serveral ports in the DMZ. I know I would have to look out for VLAN hoping attacks but is it ok to do this?
Gav
1 REPLY
Purple
Re: DMZ
Hi Gav,
In a strict security sense, that would not be a wise thing to do. The fact that the switch is 'outside' means that the switch could possibly be compromised, which in turn compromises oyour DMZ. I would provide complete physical separation if I were you...
Paresh
PS. Pls rate posts that help
99
