Does ASR1002 support L3 Etherchannel ?
I am wondering if the new Cisco ASR1002 can support very basic L3 Etherchannel since I am not able to ping the remote host whereas the interface is up ??
interface Port-channel10
ip address 10.201.40.5 255.255.255.252
negotiation auto
interface GigabitEthernet0/0/0
no ip address
negotiation auto
channel-group 10
interface GigabitEthernet0/0/1
no ip address
negotiation auto
channel-group 10
_______________
Port-channel10 is up, line protocol is up
Hardware is GEChannel, address is 0024.14f3.fcc0 (bia 0024.14f3.fcc0)
Internet address is 10.201.40.5/30
MTU 1500 bytes, BW 2000000 Kbit, DLY 10 usec,
Keepalive set (10 sec)
No. of active members in this channel: 2
Member 0 : GigabitEthernet0/0/0 , Full-duplex, 1000Mb/s
Member 1 : GigabitEthernet0/0/1 , Full-duplex, 1000Mb/s
No. of PF_JUMBO supported members in this channel : 2
Last input 00:00:12, output never, output hang never
Input queue: 0/750/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/80 (size/max)
942 packets input, 21760 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
0 watchdog, 0 multicast, 0 pause input
198 packets output, 8501 bytes, 0 underruns
0 lost carrier, 0 no carrier, 0 pause output
Any advices ?
Thanks in advance !
Re: Does ASR1002 support L3 Etherchannel ?
Hall of Fame Super Silver
Hello Nicolas,
try to use vlan based subinterfaces (enc dot1q xx) like port-channel10.20
see this chapter from configuration guide
http://www.cisco.com/en/US/docs/ios/lanswitch/configuration/guide/lsw_cfg_gecvlan_ps9587_TSD_Products_Configuration_Guide_Chapter.html
ASR 1000 should be able to map different vlans to different member links with the primary secondary option.
Other collegues have seen this vlan based load sharing in action.
Hope to help
Giuseppe
2479
