Webcast-Catalyst9k
Does ASR1K SPA-24CHT1-CE-ATM supports IMA?
Hi all,
Can you please help me to validate if the SPA-24CHT1-CE-ATM for an ASR1006 with IOS-XE version 3.10S or later supports IMA (Inverse Multiplexing for ATM) groups/configurations for its E1 ports?
I want to validate this for a C7206VXR migration which currently has active IMA E1 links using PA-IMA-E1 cards.
I already verified the configurations guides and release notes of the latest ASR1000 IOS-XE versions, but only on the release notes for IOS-XE 3.10S there is a note indicating from that version the related 24xE1 ports SPA supports ATM clear-channel configs but nothing really confirms if IMA is also supported.
The datasheet of the SPA-24CHT1-CE-ATM says that it supports IMA but I want to be sure if the configuration of IMA groups is supported in an ASR1K using IOS-XE.
Thanks for your help,
CB
26
