Does Cisco 1811 know about PPPoE?
Who knows, can I use Cisco 1811 (or 18xx series) to establish PPP connection over Ethernet(PPPoE)?
If not, what model should I use to do it (Cheaper model is prefered).
1 ACCEPTED SOLUTION
Re: Does Cisco 1811 know about PPPoE?
Yes, you can absolutely use an 1811 to do PPPoE. You can also use a lower comparable line such as the 871. Both have dual-ethernet with managed switches. The 800 series has less capacity, and fewer features.
Thanks! - )
I will kill our partners, who integrate Cisco for us!
What was recommended?
We've got aprove for Cisco 1811(for PPPoE). But after about month post-buy our Cisco integrator told that it's impossible to use such model because it's not able to make PPPoE.
But couple of days ago they told us new IOSs or insertions solved this problem and we can make PPPoE.
But now after your answer I have new question for integrator. Why not 800 series?
below config has been tested successfully on 1712 router with ADSL. see if this helps.
vpdn enable
vpdn-group pppoe
request-dialin
protocol pppoe
interface FastEthernet0
no ip address
duplex auto
speed auto
pppoe enable
pppoe-client dial-pool-number 1
i
interface Dialer1
mtu 1472
ip address negotiated
ip nat outside
ip virtual-reassembly
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp chap hostname abc.com.au
ppp chap password xxxxxxx
ip access-list standard SET-DF-0
access-list 1 permit 10.10.10.0 0.0.0.255
929
