Does VIP4-50 support PA-2CE1/PRI-75?pls advice.
Hi Team
I'd like to know wheter VIP4-50 supports PA-2CE1/PRI-75.I've been searching at cisco.com for a while but haven't got any info helpful.
Thank you very much .
Jun
1 ACCEPTED SOLUTION
Silver
Re: Does VIP4-50 support PA-2CE1/PRI-75?pls advice.
Hi Tony
I'm afraid the answer is no. Here you are the List of Port Adapters Supported by VIP4 :
http://www.cisco.com/en/US/products/hw/routers/ps359/prod_module_installation_guide09186a008065cbca.html#wp121807
As you can see PA-2CE1/PRI-75 is not listed. Software Advisor also does not list that PA as supported in VIP4
Silver
Hi Tony
thank you very much!I appreciate your help.
Have a nice weekend.
Jun
103
