Webcast-Catalyst9k
dot1q tunneling
I have a network topology as shown in document in the attachment. If second provider doesn't tunnel BPDU packets(i.e. missconfiguration), is it possible to have a layer 2 loop? Will PROVIDER 2 drop bpdu packets, or there is some mechanism that will take care situations like this?
regards,
A.
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: dot1q tunneling
Hello Antonio,
yes your switches need to be aware that both links are going to the same place unless you are permitting two different sets of vlans with no overlapping it will create a loop.
providers switches cannot distinguish between vlans to be tunneled and vlans to be blocked you need to use
swithcport trunk allowed vlan
to define only the needed vlans that should go over each pipe.
Hope to help
Giuseppe
Re: dot1q tunneling
I couldnt view the attach file, however, Tunneling from the provider prespective shouldnt dropp BPDus unless BPDU filtering is configured at the provider edge.
So, the result , with QinQ tunneling , you could still have layer2 loops.
Mohamed
Re: dot1q tunneling
I've attached topology now as a word document.
The thing is that I don't know if any link in network will be blocked in this scenario, because PROVIDER 2 dosen't tunnel BPDUs. And consequence is layer 2 loop.
A
Re: dot1q tunneling
Hello Antonio,
also the second provider should implement L2 protocol tunneling for STP.
otherwise a loop can occur
the tunnel port should automatically enable bpdu filtering of service provider STP instances.
Hope to help
Giuseppe
Re: dot1q tunneling
Yes, In this case , you could end up with layer-2 loop.
Mohamed
Re: dot1q tunneling
So this could be or definitely is a layer2 loop?
just a clarification: PROVIDER 1 and 2 has configured dot1q tunneling for my VLANs. SWITCH1 and 2 have trunk on their ports towards PROVIDERS.
A
Re: dot1q tunneling
Hello Antonio,
Hope to help
Giuseppe
Re: dot1q tunneling
Thanks Giuseppe.
142
