Routing
Don't miss this Cisco Catalyst 8000 offer
Labels
Finding accurate answers to your questions and issues is always gratifying, but what if these answers are shared globally across different languages? The Cisco Community team has been working on a proof of concept (PoC) to take Accepted Solutions in...
Kelli Glass by Community Manager
  • 10281 Views
  • 7 replies
  • 16 Helpful votes
Hi Guys, i had this problem for 8 hours now and can't seem to get it cracked... after i input the command copy xmodem: flash:c2960-lanbasek9-mz.152-7.e9.binand using the SecureCRT going to Transfer > send xmodem I get this and after that nothing happ...
hi guys thanks for your suggestions in advancei just reconsidered my whole message. after trying some things. i think i need to set up acl but i'm far from good at it.what would be the ip access-list extended or access-list lines that'd allow me to h...
gabecz by Level 1
  • 169 Views
  • 3 replies
Hi, we have a WAN and VSAT connection to one of the site. WAN is primary and VSAT is secondary link.We have dedicated router for WAN and VSAT. VSAT link is connected to one of the LAN access switch.Could you please help me, what kind of configuration...
inhamit by Level 1
  • 248 Views
  • 9 replies
I have upgraded the OS of the Nexus 3064 but I am unable to still do the capping on the sub-interface level VLANs? Does anyone know what the correct command to use for Nexus subinterfaces to create a capping on them? any syntax available in SvIInterf...
Azhaq by Level 1
  • 76 Views
  • 0 replies
We have several C1117-4PLTEEA routers. With firmware:Cisco IOS XE Software, Version 16.09.02Cisco IOS Software [Fuji], ISR Software (ARMV8EB_LINUX_IOSD-UNIVERSALK9_IAS-M), Version 16.9.2, RELEASE SOFTWARE (fc4) Some of them work perfectly and some of...
Hi,We have mGRE DMVPN tunnle between one Hub and 7 Spokes. Other 6 Spokes are working fine but one Spoke is not connecting to Hub.Spoke shows DMVPN on IKE state (tunnle is not working) and Hub is not adding nhrp entry in table.Spoke DMVPN TunnelPleas...
INBKIT_0-1713981579965.png INBKIT_3-1713982713738.png INBKIT_4-1713982931986.png INBKIT_5-1713983001947.png
INBK-IT by Level 1
  • 134 Views
  • 3 replies
Hello, I know very little about configuring cisco hardware and need some help..... we are currently running an 1800 router and I obtained a new to me 1921 router and would like to replace the 1800 router with the newer one, I managed to get it factor...
cwasilak by Level 1
  • 75 Views
  • 1 replies
The host for my current server (Windows Hyper-V machine with four or five VMs) that handles my email and web sites is going away. I'm planning on moving that physical server to my house and using DDNS to route that traffic in. Realize this is very lo...
Can someone tell me how do I do routing here ? it does not matter if it is static or dynamic I just want to ping same vlans and also I dont want to have different vlans to be pinged
