Community Member
Download Speed Problem - Cisco 806
I have a Cisco 806 router with the firewall IOS release 12.3(20). The Internet connection is Road Runner cable. Upload speeds are what they should be, 375 kbs to 484 kbs, but the download speeds are terrible, usually around 175 kbs. When attaching a computer directly to the cable modem, the computer gets 4 mbs or more download.
The IOS is doing ip inspect in and out, NAT, and no access-lists in or out (removed them for testing). No matter what I do, the download bandwidth does not go up. I even removed both ip inspects with no better download speeds.
Is this router just not up to the task or am I missing something? Ideas and suggestions are welcome.
Silver
Re: Download Speed Problem - Cisco 806
Please search the old posts that may be due to the MTU size or tcp-mss adjust issue.
Please provide the "show interface" to determine if there is packet drop or any error.
Hope this helps.
Community Member
Thank you for your reply and I appologize for not getting back to you sooner. MTU is 1500. I looked at old posts and many Cisco articles and tried to adjust MTU to 1492, but the "show interface" indicates the MTU is still 1500. I also played with the tcp-mss with no better results.
Below is the show interface. My running config, which was slightly edited to take out a few lines for security reasons is posted in another reply (too big for one post). The functionality of the script remains with interfaces and access-lists intact.
solroute#sh int
Ethernet0 is up, line protocol is up
Hardware is PQUICC Ethernet, address is 0009.b74d.fcce (bia 0009.b74d.fcce)
Description: Sailaway LAN Interface
Internet address is 10.10.10.1/24
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
Keepalive set (10 sec)
Half-duplex, 10Mb/s
Last input 00:00:00, output 00:00:00, output hang never
Input queue: 0/32/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/100 (size/max)
5 minute input rate 45000 bits/sec, 7 packets/sec
5 minute output rate 33000 bits/sec, 7 packets/sec
108992 packets input, 17242741 bytes, 0 no buffer
Received 14238 broadcasts, 0 runts, 0 giants, 0 throttles
123575 packets output, 69837637 bytes, 0 underruns
0 output errors, 2423 collisions, 0 interface resets
0 babbles, 0 late collision, 3464 deferred
0 lost carrier, 0 no carrier
Ethernet1 is up, line protocol is up
Hardware is PQUICC_FEC, address is 0009.b74d.fccf (bia 0009.b74d.fccf)
Description: Sailaway WAN Interface
Internet address is 70.124.217.227/21
Half-duplex, 10Mb/s
Last input 00:00:00, output 00:00:05, output hang never
Input queue: 0/75/5176/0 (size/max/drops/flushes); Total output drops: 0
Output queue: 0/40 (size/max)
5 minute input rate 36000 bits/sec, 12 packets/sec
5 minute output rate 39000 bits/sec, 1 packets/sec
2346123 packets input, 211244321 bytes, 58 no buffer
Received 2228622 broadcasts, 0 runts, 0 giants, 0 throttles
121 input errors, 0 CRC, 0 frame, 121 overrun, 0 ignored
117832 packets output, 17345591 bytes, 0 underruns
0 output errors, 419 collisions, 0 interface resets
0 babbles, 0 late collision, 5055 deferred
Community Member
Here is my running configuration, which was too large for my last post. Thanks for your help.
version 12.3
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname router
boot-start-marker
boot-end-marker
enable secret xxx
clock timezone est -5
clock summer-time edt recurring
no aaa new-model
ip subnet-zero
ip tcp window-size 750000
ip name-server 10.10.10.10
ip name-server 65.32.1.70
ip inspect name myfw ftp timeout 3600
ip inspect name myfw http timeout 3600
ip inspect name myfw rcmd timeout 3600
ip inspect name myfw realaudio timeout 3600
ip inspect name myfw smtp timeout 3600
ip inspect name myfw tftp timeout 30
ip inspect name myfw udp timeout 15
ip inspect name myfw h323 timeout 3600
ip inspect name myfw icmp
interface Ethernet0
description Sailaway LAN Interface
ip address 10.10.10.1 255.255.255.0
ip access-group 110 out
ip mtu 1492
ip nat inside
ip inspect myfw in
ip tcp adjust-mss 1452
no cdp enable
hold-queue 32 in
hold-queue 100 out
interface Ethernet1
ip address dhcp
ip mtu 1492
ip nat outside
ip inspect myfw out
no ip route-cache
no cdp enable
ip nat inside source list 102 interface Ethernet1 overload
ip nat inside source static tcp 10.x.x.107 3389 70.124.217.227 3389 extendable
ip classless
no ip http server
no ip http secure-server
access-list 23 permit 10.10.10.0 0.0.0.255
access-list 102 permit ip 10.10.10.0 0.0.0.255 any
access-list 110 permit ip any any
access-list 111 permit icmp any any administratively-prohibited
access-list 111 permit icmp any any echo
access-list 111 permit icmp any any echo-reply
access-list 111 permit icmp any any packet-too-big
access-list 111 permit icmp any any time-exceeded
access-list 111 permit icmp any any traceroute
access-list 111 permit icmp any any unreachable
access-list 111 permit udp any eq bootpc any eq bootpc
access-list 111 permit udp any eq bootps any eq bootps
no cdp run
line con 0
stopbits 1
line vty 0 4
access-class 23 in
exec-timeout 120 0
login local
length 0
scheduler max-task-time 5000
sntp server 192.x.41.40
sntp server 192.x.41.41
end
Silver
Acording to the output, I found both interfaces are 10Mbps half-duplex. Can you double confirm the connected device is the same setting ?
Moreover, due to 806 is a low-end model, the performance is not high. Could you try to remove the "ip inspect" command from both Ethernet interface. Moreover, try to reconfigure the MTU to 1500 or just remove it. Because it is fixed by Ethernet interface. If the WAN side is DSL, you may need to configure it.
If you remove the "ip inspect" command and the router becomes faster then you may consider to disable this feature or upgrade the router to higher model. e.g. 85x or 87x model.
Hope this helps.
Community Member
Connected devices are set to the same settings as the router - 10 Mbps, half-duplex. The ip inspect command was removed as was the MTU entry which attempted to change the MTU to 1492 but did not. The MTU has always been 1500.
After removing the commands, the speed increased by a factor of 6. The download speed is now over 1200 Kbs, which is still low for the broadband connection I have.
I guess the 806 is just not up to the challenge. That is surprising since I had a cheap $50 Linksys router on the line until a storm zapped it. Bandwidth measured with it in place frequently approached 5 Mbps download. Looks like it is time to deep six the Cisco router and buy its cheaper cousin.
Silver
You're welcome. I believe the Linksys router is a updated model and many of the processing may be hardware-based. And the 806 is outdated and even EOS, many processes are running on CPU, so more process will cause higher loading. And there are many features that you may not required but built-in the router, so it also slow down it.
If only for DSL Internet connection, Linksys may be better. Simplier is faster. Just my 2 cents. :)
388
