Draft 1721 router config (frame relay to WIC T1 DSU/CSU to ENET Lan I/F)
Need another pair of eyes to review the following draft config. The objective is to connect an internal Lan to the Internet via Frame Relay circuit using a Cisco 1721 router with WIC T1 DSU/CSU and Ethernet Lan Interface. Firewall connection intentionally left out for simplicity.
Helpful criticism wille gratefully accepted.
version 12.3
service timestamps debug datetime localtime show-timezone
service timestamps log datetime localtime show-timezone
hostname xxxxxxxxxxxx
boot-start-marker
boot-end-marker
enable secret xxxx.
enable password xxxxx
clock timezone EST -5
clock summer-time EDT recurring
mmi polling-interv
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no aaa new-model
ip subnet-zero
ip cef
no ftp-server write-enable
interface FastEthernet0
description To office Ethernet
ip address xx.xxx.xx.x 255.255.255.224
speed auto
no keepalive
interface Serial0
description To UUNET (xxxxxxxxxxxx)
bandwidth 1536
no ip address
encapsulation frame-relay IETF
no fair-queue
frame-relay interface-dlci xxx
frame-relay lmi-type ansi
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0
no ip http server
access-list 3 remark Default reference clock for local use
access-list 3 remark Massachusetts Institute of Technology Timeclock
access-list 3 permit xx.xx.x.xxx
access-list 3 remark ViaNet Communications Timeclock
access-list 3 permit xxx.xx.x.x
access-list 3 deny any log
line con 0
line aux 0
line vty 0 4
password cisco
login
ntp clock-period 17180092
ntp source FastEthernet0
ntp access-group peer 3
ntp server xx.xx.x.xxx source FastEthernet0 prefer
ntp server xxx.xx.x.x source FastEthernet0
end
1 REPLY
Purple
Re: Draft 1721 router config (frame relay to WIC T1 DSU/CSU to E
Here's a couple of things:
- what size is your Internet PVC ? you have not enabled any traffic shaping. Unless your PVC is the same size as the access rate, it may be advisable to turn on shaping.
- why have you hard-coded the LMI type to ANSI ? Is this what the ISP uses ? If not, you could just remove that command and the router will auto-detect it....
- your default route points to a multiaccess segment...This is not a good idea .. Instead of doing that, configure it with an IP next-hop..
Hope that helps - pls rate the post if it does.
Paresh
303
