DRAM fills up of C831 and C1700 routers
Please find below problem describtion of my customer:
We have about 30 Ciscon 800 -ja 1700 series routers in management
and in more than 10 routers have problem with filling up of memory.
Memory fills up and after that we are not able to connect to device.
It needs to be re-booted.
Router:
Cisco IOS Software, C1700 Software (C1700-K9O3SY7-M), Version
12.3(7)XR3, RELEASE SOFTWARE (fc2) Synched to technology version
12.3(7.11)T1
49MB DRAM memory, 97% of which is in use
Router:
Cisco IOS Software, C831 Software (C831-K9O3SY6-M), Version 12.3(7)XR3,
RELEASE SOFTWARE (fc2) Synched to technology version 12.3(7.11)T1
17MB DRAM memory, 98% of which is in use
Router:
12.3(7.11)T1
48MB DRAM memory, 98% of which is in use
Sometimes it takes about one month to fill up the memory.
Usage of memory seems grow in steps.
Could this be IOS-version problem or configuration issue?
1 REPLY
Purple
Re: DRAM fills up of C831 and C1700 routers
It seems like a memory leak of some sort.
Would you be able to post the output of 'show memory allocating-process totals' - the output can be quite long, but the first 50 lines or so should be fine.
Paresh
113
