Dram in 3845 router
I have some 3845 routers with 25MB Dram,time has come to upgrade to 512MB
is there antway to determine the existing Dram is 1 x 256MB or 2 X 128MB
obviously if it is 1 x 256MB then I only need to get another 256MB to bring it up to 512MB, but if it is 2x 128MB then would have to get a 512MB twice the cost!
These routers are in production so want minimum downtime,so is there a command that will tell you where the memory is located slot0/slot1 on the main CPU board??
VIP Super Bronze
Re: Dram in 3845 router
Hi Richard,
I think It is one 256 DRAM
256 to 512MB DRAM (single DIMM) Factory upgrade for 3800
Here is more info:
http://www.cisco.com/en/US/prod/collateral/routers/ps5855/product_data_sheet0900aecd8016a8e8.html
Reza
Hall of Fame Super Gold
Mate,
I believe the 3800 has only ONE DRAM slot. You can always e-bay your excess stock.
Thnks guys,
I think the same, pity there is not a show command to verify
Cisco never made a router with more than one DRAM slot. It used to be two Flash slots until the 2690/3700 when they started using Type 2 CF.
255
