DRAM memory upgrade for VIP2-10, VIP2-15, CX-FEIP2-2TX, and CX-FEIP2-2FX
I would like to know if is it possible upgrade memory in a CX-FEIP2. I think my Processor is using one of these part numbers: V2-10/15/FE2-UPG= or
VIP2-10/15/FE2-UPG.
Slot 5:
Physical slot 5, ~physical slot 0xA, logical slot 5, CBus 1
Microcode Status 0x4
Master Enable, LED, WCS Loaded
Board is analyzed
Pending I/O Status: None
EEPROM format version 1
FEIP2 controller, FRU: CX-FEIP2-(2TX/2FX)=, HW rev 2.14, board revision C0
Serial number: 27702267 Part number: 73-1684-05
Test history: 0x00 RMA number: 00-00-00
Flags: cisco 7000 board; 7500 compatible
EEPROM contents (hex):
0x20: 01 20 02 0E 01 A6 B3 FB 49 06 94 05 00 00 00 00
0x30: 60 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00
Slot database information:
Flags: 0x4 Insertion time: 0x2A1C (35w5d ago)
Controller Memory Size: 32 MBytes DRAM, 2048 KBytes SRAM <<<<<<<<<<-----------------------
Startup time: 2836 msec
PA Bay 0 Information:
Fast-Ethernet PA, 1 ports, 100BaseTX-ISL, FRU: PA-FE-TX-ISL=
HW rev 1.04, Board revision B0
Serial number: 27739883 Part number: 73-2570-02
PA Bay 1 Information:
Serial number: 27739635 Part number: 73-2570-02
I found the possible successor can be as follow:
VIP2-40 with MEM-VIP240-64MB-D or MEM-VIP240-128MB-D
VIP2-50 with MEM-VIP250-64M-D or MEM-VIP250-128M-D
Can these memories using in VIP modules be used in FEIP modules?
I will appreciate a lot if someone could send me an answer about this information.
1 REPLY
Re: DRAM memory upgrade for VIP2-10, VIP2-15, CX-FEIP2-2TX, and
I found the links below but it is not aswered my question:
http://www.cisco.com/en/US/products/hw/routers/ps359/products_documentation_roadmap09186a00801c0fcc.html
http://www.cisco.com/en/US/docs/routers/7500/vip2/installation/guide/2658vip2.html#wp21605 http://www.cisco.com/en/US/docs/routers/7500/vip2/installation/guide/2658vip2.html%23wp21605>
http://www.cisco.com/en/US/products/hw/routers/ps359/prod_installation_guide09186a00800f251e.html#wp3560 http://www.cisco.com/en/US/products/hw/routers/ps359/prod_installation_guide09186a00800f251e.html%23wp3560>
152
