Dropped packets with 2821 router with IOS 12.4(10c)
We discover, that one of our 2821 routers sometimes drops packets inside a running conversation. Another problem is, that SYN ACK sometimes leaves our 2821 with wrong TCP/IP sequence numbers
IOS Version is 12.4(10c) basic ip (c2800nm-ipbase-mz.124-10c.bin).
We use policy-based traffic shaping outbound, but the problem also exists inbound.
VRRP is enabled for fail over...
Screenshot 1 shows normal operation in an 3 hop analysis (left and middle is around our cisco).
Screenshot 2 shows wrong sequence numbers
Screenshot 3 shows dropped packets
Maybe only a IOS bug. 10c is very old ...
Here our configuration (without personal infomations like password and external ip adress):
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname ci2821
boot-start-marker
boot-end-marker
logging buffered 51200 debugging
logging console critical
enable secret 5 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
enable password 7 xxxxxxxxxxxxxxxxxxxx
no aaa new-model
clock timezone PCTime 1
clock summer-time PCTime date Mar 30 2003 2:00 Oct 26 2003 3:00
ip tcp synwait-time 10
no ip cef
no ip bootp server
ip domain name xxxxxxxxxxxxxxxxx
ip name-server 10.254.2.101
ip name-server xxxxxxxxxxxxxxxxx
class-map match-all nl_h-gk
match access-group 101
class-map match-all nl_dt
match access-group 102
class-map match-all nl_tptest
match access-group 103
class-map match-all nl_ha
match access-group 105
policy-map shape_h-gk
class nl_h-gk
  shape average 1000000
class nl_dt
  shape average 750000
class nl_ha
interface GigabitEthernet0/0
description DMZ NL2
ip address 192.168.3.20 255.255.255.0
duplex auto
speed auto
vrrp 10 ip 192.168.3.1
vrrp 10 priority 110
no mop enabled
interface GigabitEthernet0/1
description DMZ NL1$ES_LAN$
ip address 192.168.0.20 255.255.255.0
duplex auto
speed auto
vrrp 11 ip 192.168.0.10
vrrp 11 priority 110
no mop enabled
service-policy output shape_h-gk
ip default-gateway 192.168.3.10
ip route 0.0.0.0 0.0.0.0 192.168.3.10
ip route 10.252.0.0 255.255.0.0 192.168.0.60
ip route 10.253.0.0 255.255.0.0 192.168.0.60
ip route 10.253.82.0 255.255.255.0 192.168.0.1
ip route 10.253.100.0 255.255.252.0 192.168.0.12
ip route 10.253.100.8 255.255.255.255 192.168.0.1
ip route 10.253.104.0 255.255.255.0 192.168.0.1
ip route 10.253.109.0 255.255.255.0 192.168.0.1
ip route 10.253.112.0 255.255.255.0 192.168.0.1
ip route 10.253.113.0 255.255.255.0 192.168.0.1
ip route 10.253.115.0 255.255.255.0 192.168.0.1
ip route 10.253.200.0 255.255.255.0 192.168.0.1
ip route 10.253.201.0 255.255.255.0 192.168.0.40
ip route xxxxxxxxxxxxx 255.255.255.128 192.168.0.1
ip route 192.168.120.0 255.255.255.0 192.168.0.1
ip http server
logging trap debugging
access-list 101 permit tcp host 10.254.2.142 10.253.90.0 0.0.1.255 eq 9100
access-list 102 permit tcp host 10.254.2.142 10.253.122.0 0.0.0.255 eq 9100
access-list 103 permit tcp host 10.254.2.142 192.168.0.0 0.0.0.255 eq 9100
access-list 104 permit tcp host 10.254.2.149 192.168.0.0 0.0.0.255 eq 9100
access-list 105 permit tcp host 10.254.2.142 10.253.30.0 0.0.0.255 eq 9100
no cdp run
control-plane
alias exec ct conf term
alias exec sr show running-config
alias exec ss show startup-config
alias exec sp show policy-map interface fast 0/1
alias exec wm write memory
alias exec confsave copy running-config tftp://10.254.2.97
alias exec confload copy tftp://10.254.2.97 running-config
line con 0
line aux 0
line vty 0 4
password xxxxxxxxxxxxxxxxx
login
scheduler allocate 20000 1000
end
  • WAN Routing and Switching
Everyone's tags (6)
751
