07-24-2014 12:01 AM - edited 03-04-2019 11:25 PM
Hello colleagues
The problem is, that i have ~ 7-8 Mbps on 65Mbps link, but my service policy seems to drop packets according to queue size.
In my understanding, policy map start to drop traffic only when congestion appear, is it so?
same situation on ASR 1002 and 7206
ios Version 15.2(4)S4 and Version 15.1(4)M7
Here is config for policy map on WAN link
class-map CRITICAL
match precedence 5
class-map match-any IMPORTANT
match precedence 3
match precedence 6
class-map BUSSINESS
match precedence 1
policy-map SHAPING
class class-default
shape average 65000000
service-policy SP-QOS
policy-map SP-QOS
Class CRITICAL
priority percent 70
Class IMPORTANT
bandwidth percent 12
Class BUSSINESS
random-detect dscp-based
Class class-default
bandwidth percent 6
random-detect
interface GigabitEthernet0/0/1.9
encapsulation dot1Q 9
ip address xxxxxxxxx
ip nat outside
ip nbar protocol-discovery
service-policy output SHAPING
and here, what I see in statistic
Service-policy output: SHAPING
Class-map: class-default (match-any)
129798770 packets, 40181696005 bytes
5 minute offered rate 7304000 bps, drop rate 0000 bps
Match: any
Queueing
queue limit 270 packets
(queue depth/total drops/no-buffer drops) 0/11680/0
(pkts output/bytes output) 129779213/40165064207
shape (average) cir 65000000, bc 260000, be 260000
target shape rate 65000000
Service-policy : SP-QOS
queue stats for all priority classes:
Queueing
queue limit 512 packets
(queue depth/total drops/no-buffer drops) 0/0/0
(pkts output/bytes output) 13484092/3912327041
Class-map: CRITICAL (match-all)
13480980 packets, 3911647909 bytes
5 minute offered rate 422000 bps, drop rate 0000 bps
Match: precedence 5
Priority: 70% (45500 kbps), burst bytes 1137500, b/w exceed drops: 0
Class-map: IMPORTANT (match-any)
7721261 packets, 1021340017 bytes
5 minute offered rate 108000 bps, drop rate 0000 bps
Match: precedence 3
Match: precedence 6
Queueing
queue limit 64 packets
(pkts output/bytes output) 7715467/1020879486
bandwidth 12% (7800 kbps)
Class-map: BUSSINESS (match-all)
47724414 packets, 15630803933 bytes
5 minute offered rate 3393000 bps, drop rate 0000 bps
Match: precedence 1
Queueing
(queue depth/total drops/no-buffer drops) 0/7388/0
(pkts output/bytes output) 47741826/15628877447
Exp-weight-constant: 4 (1/16)
Mean queue depth: 1 packets
dscp Transmitted Random drop Tail drop Minimum Maximum Mark
pkts/bytes pkts/bytes pkts/bytes thresh thresh prob
af11 2990415/861605540 25/32285 645/884994 28 32 1/10
af12 677310/367870926 0/0 10/5466 24 32 1/10
af13 154681/48657019 3/1634 4/307 20 32 1/10
60817716 packets, 19603759092 bytes
5 minute offered rate 3363000 bps, drop rate 0000 bps
Match: any
Queueing
(queue depth/total drops/no-buffer drops) 0/4292/0
(pkts output/bytes output) 60837828/19602980233
bandwidth 6% (3900 kbps)
class Transmitted Random drop Tail drop Minimum Maximum Mark
0 3474437/1110326227 269/276936 742/851882 16 32 1/10
1 0/0 0/0 0/0 18 32 1/10
2 0/0 0/0 0/0 20 32 1/10
3 0/0 0/0 0/0 22 32 1/10
4 0/0 0/0 0/0 24 32 1/10
5 0/0 0/0 0/0 26 32 1/10
6 0/0 0/0 0/0 28 32 1/10
7 0/0 0/0 0/0 30 32 1/10
07-24-2014 01:35 AM
i think i understand why there are drops. Looks like RED is working fine and do some drops in order to avoid congestion
PS. Nope, still see that Tail Drops counter is growing
10-02-2014 01:46 AM
Hi, Is that fixed?
10-02-2014 02:06 AM
i still see a little bit dropped packets, but not so much as at first. i tuned a little parameters, acording to Akash advices.
10-09-2014 06:53 PM
Have you tried to remove random-detect ?
10-15-2014 11:21 PM
no, i need random detect on this queue. But, random drops has their own counter in this output (Random drop pkts/bytes). And i`m confused about tail drops
10-15-2014 11:41 PM
So tried that increasing threshold min and max right?
1. queue limit
2. Exp-weight-constant
http://www.cisco.com/c/en/us/products/collateral/ios-nx-os-software/quality-of-service-qos/white_paper_c11-481499.html
we had exact similar issue, but looks like need to consider what traffic going through the class, if like replication/file copying which using extreme burst packets ... then looks like that random-detect is checking utilization dropping some packets randomly and never gets the maximum bandwidth ... so may be looking for fair queue and remove that random-detect ... after that our link and that class is working 100%.
10-16-2014 01:54 AM
Thank you!
yes, there is some burst traffic... i`ll try you suggestion!
10-16-2014 09:58 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Why do you need RED?
As the other posters have already noted, WRED (default) parameters are likely insufficient for 65 Mbps. (Often Cisco defaults appears to be what you would want for a "typical" T1/E serial WAN link.)
WRED can be surprisingly difficult to configure correctly.
WRED tail drops happen when the average queue length exceeds the max threshold. I.e. very much like tail drops on a normal FIFO queue.
However, ideally, you should not see WRED tail drops, just random early drops. When you see WRED tail drops, you have an issue.
10-16-2014 09:47 PM
Yes, on most of my links i didn`t see any tail drops, just random drops. This link - is one that have such issue. Strange thing is that - all my links have very simular traffic (web,ftp,rdp) and none of them has tail drops on such small utilization.
for my understanding, please correct me if i wrong:
All parameters for RED configuration i see for this situation - is thresholds. So, we can increase max threshold in order to avoid tail drops. But if we will increase it to much, we will have a lot of non-actual traffic that waiting in a queue?
For my situation, we see small utilization of bandwith, so if i see tail drops, it mean that i have such bursty traffic, that tockens i get in one time is not enough. To avoid it - i can increase Bc. It helps a little.
If i turn off RED - there will be no mechanism for congestion avoidance on my link, and aggressive non-critical traffic will take a lot of bandwith, that`s why i want RED on class-default. Am i wrong?
10-17-2014 02:56 AM
Disclaimer
Posting
Are your other links are also using a shaper for the same bandwidth too? If so, then yes, for some reason your traffic appears to be more bursty on this interface.
Yes, anytime you increase queue depths you often also increase latency (from more packets waiting in the queue to transmit).
Also yes, increasing Bc will help allow transient bursts to pass but then you're going "overrate" for increased time intervals. That might be fine, but I assume there's a reason your shaping in the first place. If you're overrate, your WAN vendor might drop excess traffic or queue it. The problem with the former is obvious (although loss of what gets drop first might not be), but the latter also means you lose control over traffic prioritization.
Personally, if it's supported, I generally recommend FQ over WRED. If there's transient congestion within the class, FQ will insure one monster flow isn't adverse to other flows within the same class. Also, FQ should tail drop packets from the congestion causing flow(s) before the non-congested flows in that class.
BTW, for WRED to do its magic, the traffic has to be the kind that slows its transmission rate when a drop is detected, e.g. TCP.
10-17-2014 04:52 AM
all important UDP traffic (VoIP) goes to critical queue, so if any UDP goes to class-default (and WRED) -> int`s not so bad. Main traffic in class-default is TCP, so it`s ok.
why do you prefer FQ instead of WRED? how it can replace WRED?
Thank you for help!
10-17-2014 09:50 AM
Disclaimer
Posting
Why do I prefer FQ? Already explained, I thought.
How do enable FQ? Remove WRED statements from class and add fair-queue. (Note, you many need to adjust queue-length parameter.)
10-22-2014 03:49 AM
But in case of FQ, you must describe all traffic very carefully. I mean:
In case of WRED, in perfect world, i will not have monster flow - one random drop and our growing tcp flow decrease it speed. So all flow in one class will have they band in most cases and there will be not so much fight for bandwith
In case of FQ, if i will have such big flow - it will influence on all flow in a class. Only tail drop will decrease this flow speed. If in one class will be 2 big flows, they will fight for bandwith and tail droped. So bandwith utilization will be not so effective
am i wrong?
10-22-2014 10:06 AM
Disclaimer
Posting
Are you wrong? Yes and no.
First, with WRED, if there's a monster flow, along with other flows, the packet being dropped is random, i.e. it might not be from the monster flow.
Second, with WRED, the packet being randomly dropped is based on a moving average, so actual queue size can be much larger than the drop value trigger. (Interesting, because it's a moving average, packets can be also dropped when the queue is small [after shrinking]).
Third, normal WRED drops packets as they are being added to the queue, so that, along with WRED's moving average, can delay a flow "knowing" about the drop. I.e. A lot more packets can slam into your queue before the flow "knows" to slow.
Lastly, with WRED, it's one queue, so while all the above is happening, other flows are being impacted.
Yes, with FQ the monster flow will be tailed dropped, but other concurrent flows should not be. Often, the monster flow, because there's no moving average delay, may slow faster than when using WRED.
With FQ, other flows are dequeued concurrently, so the monster flow has little impact on their queuing latencies (again unlike WRED). Also again, other flow packets shouldn't be "mistakenly" dropped, as WRED can do.
In theory, a better WRED is Cisco's FRED, but its not widely provided across their products.
Interesting here's what Van Jacob has to say about RED: "there are not one, but two bugs in classic RED."
Research RED and you find lots and lots of research and variants to try to make it work better, including Dr. Floyd's (the creator of RED) revision - that should be a clue that it's not as simple as it appears.
PS:
Some later TCP implementation carefully monitor RTT, if they detect a jump in latency, they slow their flows, so for those you don't want to drop them at all.
Also note, I spent over 10 years working different QoS methodologies, in a large scale international (production) network. My experience, WRED works better with high speed links and many flows. It doesn't work so well at the slow end (i.e. T1/E1) with few flows. At the slow end, latency is the bigger issue, and FQ better manages that.
