I have a 3620 with a DS3 card in it (this is a production router) and would like to use the same DS3 card for a new 3845 router. Can someone tell me if this card is compatible with the new 3845 router?
Which card exactly are you using? If you are using the NM-1T3/E3 Port adapter I know that it will work in the 3845.
Mark
