Community Member
DS3's limit on a 7206
Can any tell what is the limit or how many ds3's can be installed in one 7206vxr router.With Cisco 7206VXR (NPE-G1) processor (revision B) with 491520K/32768K bytes of memory.
125184K bytes of ATA PCMCIA card at slot 2 (Sector size 512 bytes).
16384K bytes of Flash internal SIMM (Sector size 256K).
Any help will be appreciated
Thanks.
1 ACCEPTED SOLUTION
Purple
Re: DS3's limit on a 7206
Based on bandwidth points calculation alone, you should be able to populate all 6 slots of the 7206 with DS3 cards, even if they were the 2-port DS3 cards. That means you could have a theoretical maximum of 12 T3 ports on a 7206VXR. In practice, however, that would seem unlikely...
However, there is nothing stopping you from doing so.
Hope that helps - pls rate the post if it does.
Paresh
Purple
Paresh
Community Member
Thanks paresh
155
