DSCP Not Matching?
I have a handful of sites, and most of them seem to process our service policies properly. We use IPSEC tunnels between sites.
From a fast ethernet interface coming from our LAN, we have a service policy that tags our Citrix traffic.
IE:
BranchSite1#sh policy-map int fa0/0
FastEthernet0/0
Service-policy input: APPLICATION-CLASS-IN
Class-map: CITRIX (match-any)
115832764 packets, 12875217022 bytes
5 minute offered rate 54000 bps, drop rate 0 bps
Match: protocol citrix
40920837 packets, 3624987967 bytes
5 minute rate 9000 bps
Match: access-group 105
74911928 packets, 9250229055 bytes
5 minute rate 41000 bps
QoS Set
dscp af23
Packets marked 115832774
Class-map: class-default (match-any)
199473388 packets, 38224786140 bytes
5 minute offered rate 218000 bps, drop rate 0 bps
Match: any
Here is the policy on our outbound WAN link.
IE:
BranchSite1#sh policy-map int multi1 output class GOLD-DATA
Multilink1
Service-policy output: WAN-EDGE-OUTPUT-SPRINT
Class-map: GOLD-DATA (match-any)
115837229 packets, 20737738338 bytes
30 second offered rate 50000 bps, drop rate 0 bps
Match: ip dscp af23 (22)
115837227 packets, 20737738110 bytes
30 second rate 50000 bps
Match: ip precedence 2
0 packets, 0 bytes
30 second rate 0 bps
Queueing
Output Queue: Conversation 267
Bandwidth 40 (%)
Bandwidth 1228 (kbps)Max Threshold 256 (packets)
(pkts matched/bytes matched) 9777025/4751777650
(depth/total drops/no-buffer drops) 0/0/0
This remote site appears to be functioning correctly. The number of packets matched by dscp af23 on both policies are the same.
At our central site, we have a slightly different router configuration. The service policies are pretty similar, but in at our central site, we have the internet connections terminating on Router1, which is where the WAN-EDGE-OUTPUT-SPRINT policy lives. The IPSEC tunnel terminates on Router2, with a tunnel source of a fast ethernet interface on Router1 specified. The APPLICATION-CLASS-IN policy is applied to the LAN interface on Router2.
I cleared the counters on these 2 routers at the same time. There is a huge descrephancy between what Router2 tags, and what Router1 sees.
IE:
Router1#sh policy-map int multi1 output class GOLD-DATA
Multilink1
6082 packets, 1161428 bytes
5 minute offered rate 2000 bps, drop rate 0 bps
5 minute rate 2000 bps
0 packets, 0 bytes
5 minute rate 0 bps
Queueing
Bandwidth 45 (%)
Bandwidth 2764 (kbps)Max Threshold 256 (packets)
(pkts matched/bytes matched) 2445/468354
Router2#sh policy-map int fa0/1
FastEthernet0/1
736618 packets, 255842309 bytes
5 minute offered rate 561000 bps, drop rate 0 bps
76466 packets, 38644392 bytes
5 minute rate 111000 bps
660152 packets, 217197917 bytes
5 minute rate 433000 bps
QoS Set
dscp af23
Packets marked 736618
992673 packets, 249097895 bytes
5 minute offered rate 927000 bps, drop rate 0 bps
Match: any
Any ideas?
103
