05-14-2010 06:29 AM - edited 03-04-2019 08:29 AM
Hi There
If I looked at a router I got the log below:
router 878
Access SDSL
IOS c870-advipservicesk9-mz.124-6.T5.bin
When a router rebooted we can see that the vi2 and vi3 were not coming up together which means the ppp session is still down during that time, and then without to do anything it came up by itself after more than 1 h00.. Why? I Could be an issue with the radius server? I checked the stinger and stinger has been cleared. It's happening unfortunately to several sites DSL.
*Mar 1 08:23:09.231 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM0, changed state to down
*Mar 1 08:23:53.765 UTC: DSL 0 controller Link up! line rate: 512 Kbps
*Mar 1 08:23:53.765 UTC: %CONTROLLER-5-UPDOWN: Controller DSL 0, changed state to up
*Mar 1 08:23:59.358 UTC: %LINK-3-UPDOWN: Interface ATM0, changed state to up
*Mar 1 08:24:00.360 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM0, changed state to up
*Mar 1 08:24:08.297 UTC: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to up
*Mar 1 08:24:08.297 UTC: %DIALER-6-BIND: Interface Vi2 bound to profile Di1
*Mar 2 09:55:45.910 UTC: %DIALER-6-BIND: Interface Vi3 bound to profile Di1
*Mar 2 09:55:45.914 UTC: %LINK-3-UPDOWN: Interface Virtual-Access3, changed state to up
*Mar 2 09:55:46.908 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access2, changed state to up
*Mar 2 09:55:46.920 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access3, changed state to up
interface Dialer1
mtu 1448
ip address ********************** 255.255.255.252
no ip proxy-arp
encapsulation ppp
no ip route-cache cef
no ip route-cache
ip tcp adjust-mss 1400
dialer pool 1
no peer neighbor-route
no peer default ip address
no cdp enable
ppp max-bad-auth 3
ppp authentication chap callin
ppp chap hostname ***********************
ppp chap password 7 **************************
ppp multilink
ppp multilink fragment disable
ppp multilink mrru remote 1448
end
Ta
Mel
05-14-2010 10:04 AM
Hello Melanie,
I would rather say that two PPP sessions came up in different times one for each Virtual-access interface
PPP authentication involves DSL providers Radius servers and may be Radius proxy servers.
Are all branch routers connected to DSL of the same provider ?
Are all affected routers same model, same IOS image ? (searching for common elements)
Hope to help
Giuseppe
05-14-2010 11:00 AM
Hi Giuseppe,
Thanks for your help.
Regarding my dsl sites they are all from the same SP, and they are all 87x series routers with same IOS. It did worked well for years, but now I am seeing this bug .
During my tests, vi3 never turned up, what could block the vi3 to come up? Before vi3 got the ppp session with the remote ip address when I was doing a sh users.
Thanks again
mel
05-14-2010 03:30 PM
Hello Melanie,
check with SP if they have changed or upgraded their DSLAMs recently in their COs
An IOS upgrade carries a firmware upgrade for SDSL module, so this is also a possible path you could try to update IOS on one device and to see if behaviour improves.
There is only one point that is not clear to me: why there are two virtual-access interfaces it is like you are using two circuits or is this a 4 wire SDSL.
Hope to help
Giuseppe
