Webcast-Catalyst9k
DSL not able to connect
I have a block of static IP addresses given by my ISP. They say I should be able to assign a static IP address like the one below and be able to connect. However I am not. I also tried to change the static route to point to the DG and still no joy
The DG is 64.85.55.1
What am I doing wrong?
BLKLANSTR01#sh run
Building configuration...
Current configuration : 1092 bytes
version 12.4
no service pad
hostname BLKLANSTR01
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
ip source-route
ip cef
no ipv6 cef
archive
log config
hidekeys
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
ip address 64.85.55.19 255.255.255.224
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface Vlan1
ip address 10.116.38.1 255.255.255.0
ip nat inside
no ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 FastEthernet4
no ip http server
no ip http secure-server
ip nat inside source list 10 interface FastEthernet4 overload
access-list 10 permit 10.116.38.0 0.0.0.255
access-list 120 permit ip any any
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
scheduler max-task-time 5000
end
BLKLANSTR01#
1 REPLY
Hall of Fame Super Silver
Re: DSL not able to connect
Hello Brent,
a DSL line is an ATM interface from the point of view of a Cisco Router.
Here you are using an external box acting as DSL modem or router.
Your configuration could be fine if the the box acts as a bridge taking ethernet frames encapsulating them in ATM AAL5 PDUs and sending them over the DSL line.
But also the line has to be provisioned to accept this. (this is called RFC1483 bridged in contrast with RFC1483 routed where are IP packets to be sent in AAL% PDUs)
Ask your provider what they expect from you:
if it is IPv4 over ATM you need a DSL interface on the router and the ip address is then associated to the ATM / ADSL interface without using the external box. (RFC 1483 routed mode)
if is PPPoEoA you need to configure a PPPoE client on your router with the external box acting as an ethernet bridge.
Hope to help
Giuseppe
205
