dspsarcnt on MGX
Hi ,
Could any please explain these counters.
MyNode.1.10.VISM8.a > dspsarcnt 131
SarShelfNum: 1
SarSlotNum: 10
SarChanNum: 131
Tx Rx
Total Cells: 60724167 37944533
Total CellsCLP: 0 0
Total CellsAIS: 0 0
Total CellsFERF: 0 1
Total CellsEnd2EndLpBk: 2517672 2517264
Total CellsSegmentLpBk: 0 0
RcvCellsDiscOAM: 0
regards
Neo
  • WAN Routing and Switching
Purple
Re: dspsarcnt on MGX
Neo,
These are stats for the SAR (Segmentation & Reassembly) function for the VISM module. The first counter is the number of cells transmitted and the second is the number received
Total Cells: total number of cells transmitted and received
Total CellsCLP: total number of cells with the CLP bit set
Total CellsAIS: total number of AIS (Alarm Indication Signal) cells
Total CellsFERF: Total number of Far End Receive Failures
Total CellsEnd2EndLpBk: total number of OAM end-to-end loopback cells
Total CellsSegmentLpBk: total number of OAM segment loopback cells
RcvCellsDiscOAM: number of OAM cells discarded
I would appreciate you rating the post if it helps.
Paresh
Hi ,
thnkas for your reply.which counters should be an area of concern for me ?
regards
Neo
Purple
Hi Neo,
The ones that could indicate potential problems are:
Total CellsCLP: this may or may not be a concern depending on how your services are configured but a large proportion of cells with CLP set should be investigated.
Total CellsAIS: these indicate PVC failures
Total CellsFERF: these indicate PVC failures
Paresh
167
