Dual BGP balancing + failover
Hello.
I have neighbours set up with 'maximum-paths ibgp 2', which should allow per-packet balancing.
Is there a way to implement a route failover?
Thsnk you.
Hall of Fame Super Bronze
If you have multiple paths and one path is lost, it will failover. What exactly is the issue you are facing?
I meaned situation when both BGP sessions are alive, but one of the paths is not. In this case i need to switch to the working one, and start per-packet balancing again when the second path comes up.
Thank you.
This is how the process works by default.
275
