Dual BGP neighbors with route-maps
jon_panes24
Here in our company we have a router that is connected to 2 eBGP peers, lets say that the first peer is 1.1.1.1 and the other is 2.2.2.2. Currently, we are receiving and using a default route to 1.1.1.1, this make the 2.2.2.2 not utilized. So what we did is create a route-map that sets the ip next-hop to 2.2.2.2
example:
access-list 1 standard pernit 200.200.200.200
route-map BROWSE permit 10
match ip address 1
set ip next-hop 2.2.2.2
I wonder what happens when the 2.2.2.2 ISP goes down, will it failover to ISP1? If not is there a way of doing this type of setup with failover without using IP SLA?
Thanks.
2 Accepted Solutions
If ip address 2.2.2.2 known to your router as connected network than you don’t have to configure SLA. If 2.2.2.2 goes down, connected route will be withdrawn from routing table and route-map will not sent packets to it.
But if 2.2.2.2 isn’t directly connected, than you have to configure sla operation to track it reachability and use verify-reachability keyword in route-map.
Akash Agrawal
Setting next-hop to 2.2.2.2 for routes received from 1.1.1.1 is very bad design, this may cause blackholing of traffic or traffic loop. Say suppose, prefix which ISP1 is advertising , not available with ISP2 and we are sending traffic to ISP2 with next-hop change, eventually it may get dropped.
If you are receiving partial/full routes then you can pefer few prefixes to ISP1 and others to ISP2 with changing local preference.
If you are receving just default route then you can use "maximum-paths 2" to install both default routes into routing table and do load balance of traffic.
By default "maximum-paths 2" works only for prefixes coming from same AS. To enable same for prefixes coming from different AS, there is hidden command in BGP "bgp bestpath as-path multipath-relax"
Configuration example:
Topology
                      _______R1 (AS-100)
(AS-300) R3
                     \_______R2 (AS-200)
R1, R2 advertsiing default route to R3.
R3#sh ip bgp su | i 1.1.1.1|2.2.2.2
1.1.1.1         4          100      38      39       20    0    0 00:30:54       10
2.2.2.2         4          200      39      39       20    0    0 00:30:53        2
R3#
R3#show ip bgp 0.0.0.0
BGP routing table entry for 0.0.0.0/0, version 20
Paths: (2 available, best #2, table default)
Multipath: eBGP
  Advertised to update-groups:
    1.1.1.1 (metric 11) from 1.1.1.1 (204.90.255.1)
      Origin IGP, localpref 100, valid, external, multipath
  200
    2.2.2.2 (metric 11) from 2.2.2.2 (100.100.100.100)
      Origin IGP, localpref 100, valid, external, multipath, best
R3#
R3#sh ip route | b Gateway
Gateway of last resort is 2.2.2.2 to network 0.0.0.0
B*    0.0.0.0/0 [20/0] via 2.2.2.2, 00:00:36   <<<<<<<<<<<<<<<< preferring only 2.2.2.2
      1.0.0.0/32 is subnetted, 1 subnets
O        1.1.1.1 [110/11] via 172.31.13.1, 00:32:21, Ethernet1/0.100
After configuring "Maximum-paths 2" and "bgp bestpath as-path multipath-relax"
R3#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
R3(config)#router bgp 300
R3(config-router)#maximum-path 2
R3(config-router)#bgp bestpath as-path multipath-relax
R3(config-router)#
B*    0.0.0.0/0 [20/0] via 2.2.2.2, 00:00:19
                [20/0] via 1.1.1.1, 00:00:19  <<<<<<<<<<<<< both BGP routes got installed into routing table
O        1.1.1.1 [110/11] via 172.31.13.1, 00:33:41, Ethernet1/0.100
-- Pls dont forget to rate helpful posts --
Akash
7 Replies 7
Sandeep Sharma
There are different ways of achieving the load balancing using bgp like multipath or BGP link bandwidth feature. Refer the below link that will help you configure load balancing as per you requirement.
http://www.cisco.com/c/en/us/support/docs/ip/border-gateway-protocol-bgp/13762-40.html
Hope it answers your query.
Thanks & Regards
Sandeep
Agreed with Akash.
You can use the meximum-path 2 in order to achieve dual ISP with different AS,  its a hidden command in BGP bgp bestpath as-path multipath-relax.
#Maximum-path 2
Akash Agrawal
Topology
                      _______R1 (AS-100)
(AS-300) R3
                     \_______R2 (AS-200)
R3#
Multipath: eBGP
  200
R3#
R3#conf t
R3(config-router)#
Akash
Hi ,
Actually I have a same question but for a different Topology.
I have two routers connecting to different Service Providers (Router A to Service provider A1 and Router B to Service Provider B1).
We are using iBGP between A and B and eBGP between A to A1 and B to B1.
Can I use ''bgp bestpath as-path multipath-relax'' command to load balance/share outbound traffic between these two service providers in different AS'es ?
Where all this command be applied ? in eBGP as well as iBGP ? (we are using VRF).
I set this up in GNS3, and it seems to work. Make sure both iBGP routers have:
maximum-paths eibgp 2
configured.
R1 and R2 are the iBGP neighbors, I have configured the 77.77.77.77/32 route from the Internet, both routers have two paths:
R1
router bgp 1
bgp router-id 1.1.1.1
bgp log-neighbor-changes
neighbor 192.168.12.2 remote-as 1
neighbor 192.168.12.2 next-hop-self
neighbor 192.168.13.3 remote-as 2
R1#sh ip route
77.0.0.0/32 is subnetted, 1 subnets
B 77.77.77.77 [20/0] via 192.168.13.3, 00:00:14
[20/0] via 192.168.12.2, 00:00:14
R2
router bgp 1
neighbor 192.168.12.1 remote-as 1
neighbor 192.168.12.1 next-hop-self
neighbor 192.168.24.4 remote-as 3
R2#sh ip route
B 77.77.77.77 [20/0] via 192.168.24.4, 00:00:34
[20/0] via 192.168.12.1, 00:00:34
jon_panes24
Thanks for the reply.
