07-30-2013 03:30 PM - edited 03-04-2019 08:36 PM
I have a project that requires 2 data centers, one for a hot standby. I have 5 remote offices that need to connect to data center 1. In the event data center 1 goes down then I need the 5 remote sites to connect to data center 2.
All 5 remote offices as well as the DATA centers will have 5525x ASA's behind the boundry routers. The boundry routers will have IP/ACL and stateful packet filtering. the internal FW will be packet inspection
Both data centers will have 2 seperate internet connections plus a replication link out the back between them.
I wanted to use a multisite MPLS GRE tunnel which would originate from each remote office. In the event a remote office couldn't get to a data center then it would attempt to connect to the other data center. Question to follow........
The 2 data centers would replicate over the back channel so they wouldn't require connectivity to each other out the front.
I will eventually add dual front end routers so HSRP will be running locally
Questions:
1. Is this the best design to go with? concerned the 5 tunnels over a ds3 would be to much, unless I can load balance
2. What is the mechanism that allows MPLS GRE tunnels to load balance and create failover.
3. Has someone seen a white paper or diagram that supports this?
4. Am I missing somthing I should be considering?
07-30-2013 06:23 PM
Does DMVPN or something similar meet all requirements? You can have dual hub dual DMVPN to get active/stanby, and encryp traffic go through internet. What's the business case of running MPLS here?
Sorry about not answering your questions directly; just want to get clear on the use case. You can take a look the following link for MPLSoGRE
http://www.cisco.com/en/US/docs/solutions/Enterprise/WAN_and_MAN/ngwanearch.html#wp1000241
HTH,
Lei Tian
07-31-2013 07:21 AM
Business case for MPLS is voice ,T-1 and fault tolerance. I also need to prioritize traffic. I some traffic that is critical to receive at all times. I considered dual DMVPN just wasn't sure I could prioritize it correctly
07-31-2013 03:51 PM
You can apply QoS for DMVPN; you can prioritize voice traffic, and you can do per-tunnel QoS with DMVPN. However, you will lose control of the packets once packet gets in the internet, regardless the solution you are using.
HTH,
Lei Tian
