dual homing ospf
i have a network that i'm trying to dual home. hardware is 2 3550 which is the new network, using 2 3750 as the existing network.
requirements
1.new network is routed from its campus building to the old network building.
2.new network will be dual connected at the old building.
3.new network in the event of connection failure will reroute all traffic over other connection.
the routing protocol is ospf split into different areas.
buildings are fiber connected.
using hsrp at old campus on SVI dedicated to the 2 routed ports coming from the new building.
new builing has a trunk port between the 2 switches
using SVIs with hsrp to manage traffic at new building
voip will be running at new location
new building sw 1
interface Vlan174
ip address 10.190.174.2 255.255.255.0
ip helper-address 10.190.174.1
no ip redirects
standby 174 ip 10.190.174.1
standby 174 timers 1 3
standby 174 priority 101
standby 174 preempt
standby 174 track GigabitEthernet0/1
new building sw 2
interface Vlan174
ip address 10.190.174.3 255.255.255.0
no ip redirects
standby 174 preempt
router ospf 1
log-adjacency-changes
redistribute connected subnets
passive-interface Vlan172
passive-interface Vlan173
passive-interface Vlan175
passive-interface Vlan372
passive-interface Vlan373
passive-interface Vlan374
passive-interface Vlan375
network 10.190.170.0 0.0.0.7 area 1
network 10.190.172.0 0.0.3.255 area 172
network 10.191.172.0 0.0.3.255 area 372
maximum-paths 2
  • WAN Routing and Switching
127
