Community Member
Dual Hub + GRE Tunnel
Hello
I got Dual VPN Hub VPN scenario
At HQ we got VPN-Hub#1 && VPN-HUB#2
On each Spoke One Tunnel points to Hub#1 and second Tunnel points to Hub#2
Example on Spoke3
Tunnel 1 will be  Active Tunnel pointing to HUB#1 ( all traffic to HQ goes via this Tunnel )
Tunnel 2 will be Active tunnel  pointing to Hub#2  but no traffic will pass to HQ unless reachability to HQ is down via Tunnel 1
I tested the attached config but doesnt seems to work. ( I will have IPSEC over GRE after routing issue is resolved )
Another concern would be how to avoid recursive routing in this scenario
Please comment.
Community Member
Re: Dual Hub + GRE Tunnel
Hello
Any feedback why the attached config in original post not woking...
Bronze
To which device do IPs 1.1.1.2, 2.2.2.1 and 3.3.3.2 belong to? You use them as the next-hop in your default routes. If that IPs are not reachable your tunnel interface will be down.
I changed those next-hops by the exit interface Fa0/0 and I can ping every IP on your scenario via the tunnel.
Hope this helps.
Community Member
Yes reachability is there to HQ from Spoke3 router when Tunnel 1 is down.
But no traffic passes from Tunnel 2 to HQ and vise-versa.
From HQ SW the traffic to Spoke3 sems to hit the Hub1 instead of Hub2 ( when Tunnel 1 is down ) and traffic is drop
thansk
ST
209
