Webcast-Catalyst9k
Dual ISP 877 is this going to work?
I have setup a 877 with Adv IP as follows but I can't test till I get to site so not sure if this will work.
ADSL - ISP1
VLAN2 - Linked FE3 - ISP2
VLAN1 - Internal
I have created PBR for NAT.
I have an IP SLA track to mark the routes.
I've done this before on 1800s I think this is OK but I need to create a VPN tunnel that will switch interfaces in the event the main VLAN2 goes down. This is the bit i'm not 100% I can do.
I've attached the config.
They've changed the CBAC and ACL to this new Zones method and it confusing me a bit.
Silver
Re: Dual ISP 877 is this going to work?
yes, Dual ISP is possible on 877 routers. If you are using backup connection then make sure to configure routing.
For further information click this link.
http://www.cisco.com/en/US/docs/ios/12_3/12_3x/12_3xe/feature/guide/dbackupx.html
Using a VPN that is tied to a physical interface which is one of your ISP uplinks is likely to fall down if that ISP uplink is down.
124
