Community Member
Dual ISP (Failover) NAT Configuration - HELP!
I have the following situation:
2 ISP, 1 with fixed IP (200.1.1.1 - fake), 1 ADSL (Backup ISP) with Dynamic IP.
CISCO 1811, 12.4
1 ISA Server 2004 in the inside working as a proxy. The only internal IP address.(10.10.10.2)
Servers published on the ISA IP.
I made it work fine for outgoing traffic but need help on incoming traffic (only working with the static IP) and with lt2p/IPsec passthrough to the ISA server. I could not make the NAT: (i.e:ip nat inside source static tcp 10.10.10.2 25 interface FastEthernet0 25) work with route-maps as stated in some documents, nor with extendable.
I culd have a 1 to 1 MAP of 10.10.10.2 with the two external interfaces but could not configure it (overload gets in automatically)
Relevant config:
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
hostname border01
boot-start-marker
boot-end-marker
no ip source-route
ip cef
ip tcp synwait-time 10
track 100 ip sla 1 reachability
delay down 10 up 20
!****Fixed IP WAN
description $ES_WAN$$ETH-WAN$$FW_OUTSIDE$
ip address 200.1.1.1 255.255.255.252
ip verify unicast reverse-path
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
ip virtual-reassembly
zone-member security out-zone
ip tcp adjust-mss 1412
duplex auto
speed auto
interface FastEthernet1
description $ETH-WAN$
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-FE 2$$ES_LAN$$FW_INSIDE$
ip address 10.10.10.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
zone-member security in-zone
!****ADLS Interface
interface Dialer0
description $FW_OUTSIDE$
ip address negotiated
no ip proxy-arp
ip mtu 1452
ip flow ingress
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname k35035@adsl51
ppp chap password 7 060F1B321D1C5E
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 200.1.1.2 track 100
ip route 0.0.0.0 0.0.0.0 Dialer0 100
ip route 200.2.2.2 255.255.255.255 200.1.1.2
ip nat inside source static tcp 10.10.10.2 443 interface FastEthernet0 443
ip nat inside source static tcp 10.10.10.2 110 interface FastEthernet0 110
ip nat inside source static tcp 10.10.10.2 80 interface FastEthernet0 80
ip nat inside source route-map fixed-nat interface FastEthernet0 overload
ip nat inside source route-map ppoe-nat interface Dialer0 overload
ip access-list extended Entrante
remark CCP_ACL Category=128
permit ip any host 10.10.10.2
ip sla 1
icmp-echo 200.58.128.57 source-interface FastEthernet0
timeout 1000
frequency 3
ip sla schedule 1 life forever start-time now
logging trap debugging
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 10.0.0.0 0.255.255.255
access-list 23 permit 10.10.10.0 0.0.0.7
access-list 100 remark CCP_ACL Category=128
access-list 100 permit ip host 255.255.255.255 any
access-list 100 permit ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip 200.1.1.0 0.0.0.8 any
dialer-list 1 protocol ip permit
no cdp run
route-map fixed-nat permit 10
match ip address 1
match interface FastEthernet0
route-map ppoe-nat permit 10
match ip address 1
match interface Dialer0
AN_Y HELP is greatly appreciated...I´ve pent too much time on this
Everyone's tags (4)
1722
