Community Member
dual ISP multihoming on an 1811 router
I have a client with an 1811 router (two "WAN" ports: FE0 & FE1) who wants to connect both WAN ports up to two different ISPs for either load-balancing or a simple fail-over system. I've done some Google-ing and most of the multi-homing scenarios involve complicated BGP setups. Is there a simpler way? They don't have any outside-to-inside initiated traffic (people on the LAN basically just surf the Internet)
Their FE2-FE9 ports (Vlan1) are on a NAT-ed subnet 192.168.1.x and so the router must be keeping track of inside-to-outside flows and I would think it would be simple just to send one NAT flow to one WAN interface, and the next NAT flow to the second interface, and continuing back and forth... or am I missing something?
2 ACCEPTED SOLUTIONS
Hall of Fame Super Gold
Re: dual ISP multihoming on an 1811 router
Yes. The problem arises when one interface is up but has no connectivity. There are anyway advanced configurations that can overcome this problem also.
Community Member
Someone else posted this, I think this is what you are looking for:
ip sla 1
icmp-echo ip1 source-interface FastEthernet1
timeout 1000
threshold 30
frequency 3
ip sla schedule 1 life forever start-time now
ip sla 2
icmp-echo ip2 source-interface FastEthernet0
timeout 1000
threshold 30
frequency 3
ip sla schedule 2 life forever start-time now
track 100 rtr 1 reachability
track 101 rtr 2 reachability
ip route 0.0.0.0 0.0.0.0 ip1 track 100
ip route 0.0.0.0 0.0.0.0 ip2 track 101
ip nat inside source route-map ISP1 interface FastEthernet0 overload
ip nat inside source route-map ISP2 interface FastEthernet1 overload
access-list 100 permit ip 172.16.30.0 0.0.0.255 any
route-map ISP1 permit 10
match ip address 100
match interface FastEthernet0
route-map ISP2 permit 10
match interface FastEthernet1
This is working fine for outgoing traffic.
Basic operations, if you have no incoming services I think it will meet your need.
Silver
Definetely. In fact, BGP is meant for more complex situations, like smaller SNMP, return traffic manipulation, control etc.
Normally you would achieve desired result using static routes. If you create two identical static routes, than your internal router mechnaizms will load balance automatically between two paths. There could be a problem though, if the packet returns on an opposite port that it was sent, and dynamic NAT entry has to have this record in place for all the applicants.
Luckily with multiple ISP NAT, packets will never return on another interface than the one they were sent out.
This is because packets are sourced from ISP-specific address space and to there they will be replied.
Community Member
So are you saying (I'm hoping) that I just need to set up the WAN interfaces (both as "ip nat outside"), set up two identical cost static routes to these interfaces and it will load balance auto-magically? (I love that word)
That is great news.
Silver
Like IP SLA?
Yes, plus eem as needed, and the latest as found by Edison, oer keyword in nat statements.
Community Member
ip sla 1
timeout 1000
threshold 30
frequency 3
ip sla 2
timeout 1000
threshold 30
frequency 3
454
