Dual vlan in CAT
Hi, can i make a port part of dual vlan, that is data and voice in cat 6500 and 4006 series switches? i dont know how to.
i can do it easily in IOS bases switches.
need help
1 ACCEPTED SOLUTION
Bronze
Re: Dual vlan in CAT
If we are dealing with CATOS then you should be using the auxiliary vlan command:
set port auxiliaryvlan mod[/ports] {vlan | untagged | dot1p | none}
The auxiliary vlan here will be the voice vlan.
Hope it helps...
Bronze
Hope it helps...
yes it helped, thanx man :)
131
