dual wan router with ssl/ipsec vpn
tjd2112pcca
Hello All,
I have a question about how to set up a 1941 router with two WAN links to two different ISPs. I want all the surfing in-to-out traffic and the default route going to ISP1 and the SSL and L2L IPSEC traffic going to ISP2. The link to ISP2 would also be the failover link to the internet for the inside hosts in case the link to ISP1 went down. I have read that this can be accomplished with route maps, but I have not found any examples that meet my needs. I can post the config of the 1941 if needed.
Thanks.
6 Replies 6
Richard Burts
In general terms the solution that you are looking for is Policy Based Routing. With PBR you can use route maps to change the routing logic for certain types of traffic.
I would suggest that you approach your configuration in this order:
- set up the primary/preferred routing for Internet traffic (probably a static default route or whatever suits your requirements).
- set up failover to the other ISP connection. Depending on the type of interfaces this could be as simple as a floating static default route, or it could be more complex and need to configure some type of Object Tracking or IP SLA to recognize failure of the primary link and failover to ISP2.
- then set up PBRs for IPSec and SSL VPN traffic. The route map needs to identify the traffic for which it will use different routing logic. Matching the IPSec traffic is fairly easy since you basically need to match ISAKMP (UDP 500) and ESP (protocol 50) traffic. Matching SSL VPN may be a bit more tricky. The easy thing would be to match the SSL traffic by port number (which is TCP 443). But since browsing HTTPS is also TCP 443 you may get some overlap in your route map. You might need to use matching on the machine on your network to which people will do SSL VPN. Or you may need to come up with some other matching criteria.
Rick
Rick
Thanks for the info! I have done some initial config based on this document:
https://supportforums.cisco.com/docs/DOC-12284
I'm testing the SSL first. I'm not sure whether to use a local ip policy statement or applied to the VPN WAN interface.
You would use the local policy if the router itself were the SSL VPN gateway. You would apply the ip policy with route map to the interface where the SSL traffic arrives if the gateway is some other device in the network.
Rick
Rick
The router itself is the SSL gateway so I will make that change. Thanks!
So far it's not working. Any troubleshooting tips? I can post the config here.
Here is the config:
I think ACL 105 allows too much. I should probably change it to 10.1.9.0 0.0.0.255.
Current configuration : 19593 bytes
! Last configuration change at 15:12:52 EST Mon Nov 1 2010 by user
version 15.0
hostname router
boot-start-marker
boot-end-marker
logging buffered 51200
aaa new-model
aaa authentication login default local
aaa authentication login external-vpn-users local group radius
aaa authentication login webvpn local
aaa authorization exec default local
aaa authorization network external-vpn-groups local
aaa authorization network external-vpn-users group radius local
aaa session-id common
clock timezone EST -5
no ipv6 cef
flow record nbar
description NBAR flow monitor
match ipv4 tos
match ipv4 protocol
match ipv4 source address
match ipv4 destination address
match transport source-port
match transport destination-port
match interface input
match application name
collect datalink mac source address input
collect datalink mac destination address input
collect routing destination as
collect routing next-hop address ipv4
collect ipv4 dscp
collect ipv4 id
collect ipv4 source prefix
collect ipv4 source mask
collect ipv4 destination mask
collect transport tcp source-port
collect transport tcp destination-port
collect transport tcp flags
collect transport udp source-port
collect transport udp destination-port
collect interface output
collect flow direction
collect flow sampler
collect counter bytes
collect counter packets
collect timestamp sys-uptime first
collect timestamp sys-uptime last
flow exporter export
description flexible NF v9
destination 1.1.1.1
source GigabitEthernet0/0
transport udp 2055
template data timeout 60
option interface-table
option exporter-stats
option application-table
flow monitor mon
description app traffic analysis
record nbar
exporter export-to-tim
cache timeout active 60
ip source-route
ip cef
ip domain name domain.com
ip name-server 68.87.64.150
ip inspect audit-trail
ip inspect alert-off
ip inspect name SDM_LOW cuseeme
ip inspect name SDM_LOW ftp
ip inspect name SDM_LOW h323
ip inspect name SDM_LOW icmp
ip inspect name SDM_LOW netshow
ip inspect name SDM_LOW rcmd
ip inspect name SDM_LOW realaudio
ip inspect name SDM_LOW rtsp
ip inspect name SDM_LOW esmtp
ip inspect name SDM_LOW sqlnet
ip inspect name SDM_LOW streamworks
ip inspect name SDM_LOW tftp
ip inspect name SDM_LOW tcp
ip inspect name SDM_LOW udp
ip inspect name SDM_LOW vdolive
ip inspect name SSl_VPN https
crypto pki trustpoint TP-self-signed-1234
enrollment selfsigned
ip-address 2.2.2.2
subject-name cn=IOS-Self-Signed-Certificate-1234
revocation-check none
rsakeypair TP-self-signed-3735527223
crypto pki certificate chain TP-self-signed-1234
certificate self-signed 01
  cert
        quit
license udi pid CISCO1941/K9 sn 1111
username user
redundancy
class-map type inspect match-any CMAP-1
match protocol tcp
match protocol icmp
match protocol udp
class-map type inspect match-all pptp-passthru
match access-group name PPTP-PASS-THROUGH
class-map type inspect match-all CMAP-HTTPS
match protocol https
class-map type inspect match-all CMAP-IPSEC
policy-map type inspect PMAP-1
class type inspect CMAP-1
  inspect
class type inspect pptp-passthru
  pass
class class-default
  drop
policy-map type inspect PMAP-2
  pass
class type inspect CMAP-HTTPS
  pass
class class-default
  drop
zone security inside
zone security outside
zone-pair security inside-to-outside source inside destination outside
service-policy type inspect PMAP-1
zone-pair security outside-to-inside source outside destination inside
service-policy type inspect PMAP-2
crypto isakmp policy 10
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp key key address 4.4.4.4 no-xauth
crypto isakmp client configuration group vpn-group-1
key key
dns 10.1.9.254
wins 10.1.9.254
domain domain.com
pool vpn_users1
acl 151
netmask 255.255.255.0
crypto isakmp profile VPNclient
   match identity group vpn-group-1
crypto ipsec transform-set sonicwall esp-3des esp-md5-hmac
crypto ipsec transform-set client-tsset esp-3des esp-sha-hmac
crypto dynamic-map client-map 1
set transform-set client-tsset
set isakmp-profile VPNclient
reverse-route
crypto map external-crypto client authentication list external-vpn-users
crypto map external-crypto isakmp authorization list external-vpn-groups
crypto map external-crypto client configuration address respond
crypto map external-crypto 10 ipsec-isakmp
description Tunnel to Sonicwall / 4.4.4.4
set peer 4.4.4.4
set security-association lifetime seconds 86400
set transform-set sonicwall
match address 150
crypto map external-crypto 65535 ipsec-isakmp dynamic client-map!
interface Loopback2
description This is needed for WebVPN address pool
ip address 10.3.1.126 255.255.255.0
ip nat inside
ip virtual-reassembly
interface GigabitEthernet0/0
description Internal LAN
ip address 10.1.9.251 255.255.255.0
ip mask-reply
ip nbar protocol-discovery
ip flow monitor tim-mon input
ip nat inside
zone-member security inside
duplex auto
speed auto
no cdp enable
no mop enabled
interface GigabitEthernet0/1
description Internet via Comcast
ip address 1.1.1.1 255.255.255.248
ip nat outside
zone-member security outside
duplex auto
speed auto
no cdp enable
no mop enabled
interface FastEthernet0/0/0
description Internet via Paetec
ip address 2.2.2.2 255.255.255.240
ip verify unicast reverse-path
ip nat outside
duplex auto
speed auto
no cdp enable
no mop enabled
ip local policy route-map SSL-REDIRECT
ip local pool vpn_users1 10.2.1.1 10.2.1.100
ip local pool webvpn_users 10.3.1.1 10.3.1.100
ip forward-protocol nd
no ip http server
ip http authentication local
no ip http secure-server
ip flow-cache timeout active 1
ip nat inside source list 105 interface GigabitEthernet0/1 overload
ip nat inside source route-map nonat-vpn interface FastEthernet0/0/0 overload
ip route 0.0.0.0 0.0.0.0 1.1.1.1
ip route 0.0.0.0 0.0.0.0 2.2.2.1 250
ip access-list extended PPTP-PASS-THROUGH
permit gre any any
ip access-list extended SSL
permit tcp host 2.2.2.2 eq 443 any
no logging trap
access-list 100 remark NAT policy for this router
access-list 100 remark Deny NAT for packets via VPN
access-list 100 deny   ip 10.1.9.0 0.0.0.255 10.1.10.0 0.0.0.255
access-list 100 remark Deny NAT for packets to VPN clients (ippool)
access-list 100 deny   ip any host 10.2.1.1
access-list 100 deny   ip any host 10.2.1.2
access-list 100 deny   ip any host 10.2.1.3
access-list 100 deny   ip any host 10.2.1.4
access-list 100 deny   ip any host 10.2.1.5
access-list 100 deny   ip any host 10.2.1.6
access-list 100 deny   ip any host 10.2.1.7
access-list 100 deny   ip any host 10.2.1.8
access-list 100 deny   ip any host 10.2.1.9
access-list 100 deny   ip any host 10.2.1.10
access-list 100 deny   ip any host 10.2.1.11
access-list 100 deny   ip any host 10.2.1.12
access-list 100 deny   ip any host 10.2.1.13
access-list 100 deny   ip any host 10.2.1.14
access-list 100 deny   ip any host 10.2.1.15
access-list 100 deny   ip any host 10.2.1.16
access-list 100 deny   ip any host 10.2.1.17
access-list 100 deny   ip any host 10.2.1.18
access-list 100 deny   ip any host 10.2.1.19
access-list 100 deny   ip any host 10.2.1.20
access-list 100 deny   ip any host 10.2.1.21
access-list 100 deny   ip any host 10.2.1.22
access-list 100 deny   ip any host 10.2.1.23
access-list 100 deny   ip any host 10.2.1.24
access-list 100 deny   ip any host 10.2.1.25
access-list 100 deny   ip any host 10.2.1.26
access-list 100 deny   ip any host 10.2.1.27
access-list 100 deny   ip any host 10.2.1.28
access-list 100 deny   ip any host 10.2.1.29
access-list 100 deny   ip any host 10.2.1.30
access-list 100 deny   ip any host 10.2.1.31
access-list 100 deny   ip any host 10.2.1.32
access-list 100 deny   ip any host 10.2.1.33
access-list 100 deny   ip any host 10.2.1.34
access-list 100 deny   ip any host 10.2.1.35
access-list 100 deny   ip any host 10.2.1.36
access-list 100 deny   ip any host 10.2.1.37
access-list 100 deny   ip any host 10.2.1.38
access-list 100 deny   ip any host 10.2.1.39
access-list 100 deny   ip any host 10.2.1.40
access-list 100 deny   ip any host 10.2.1.41
access-list 100 deny   ip any host 10.2.1.42
access-list 100 deny   ip any host 10.2.1.43
access-list 100 deny   ip any host 10.2.1.44
access-list 100 deny   ip any host 10.2.1.45
access-list 100 deny   ip any host 10.2.1.46
access-list 100 deny   ip any host 10.2.1.47
access-list 100 deny   ip any host 10.2.1.48
access-list 100 deny   ip any host 10.2.1.49
access-list 100 deny   ip any host 10.2.1.50
access-list 100 deny   ip any host 10.2.1.51
access-list 100 deny   ip any host 10.2.1.52
access-list 100 deny   ip any host 10.2.1.53
access-list 100 deny   ip any host 10.2.1.54
access-list 100 deny   ip any host 10.2.1.55
access-list 100 deny   ip any host 10.2.1.56
access-list 100 deny   ip any host 10.2.1.57
access-list 100 deny   ip any host 10.2.1.58
access-list 100 deny   ip any host 10.2.1.59
access-list 100 deny   ip any host 10.2.1.60
access-list 100 deny   ip any host 10.2.1.61
access-list 100 deny   ip any host 10.2.1.62
access-list 100 deny   ip any host 10.2.1.63
access-list 100 deny   ip any host 10.2.1.64
access-list 100 deny   ip any host 10.2.1.65
access-list 100 deny   ip any host 10.2.1.66
access-list 100 deny   ip any host 10.2.1.67
access-list 100 deny   ip any host 10.2.1.68
access-list 100 deny   ip any host 10.2.1.69
access-list 100 deny   ip any host 10.2.1.70
access-list 100 deny   ip any host 10.2.1.71
access-list 100 deny   ip any host 10.2.1.72
access-list 100 deny   ip any host 10.2.1.73
access-list 100 deny   ip any host 10.2.1.74
access-list 100 deny   ip any host 10.2.1.75
access-list 100 deny   ip any host 10.2.1.76
access-list 100 deny   ip any host 10.2.1.77
access-list 100 deny   ip any host 10.2.1.78
access-list 100 deny   ip any host 10.2.1.79
access-list 100 deny   ip any host 10.2.1.80
access-list 100 deny   ip any host 10.2.1.81
access-list 100 deny   ip any host 10.2.1.82
access-list 100 deny   ip any host 10.2.1.83
access-list 100 deny   ip any host 10.2.1.84
access-list 100 deny   ip any host 10.2.1.85
access-list 100 deny   ip any host 10.2.1.86
access-list 100 deny   ip any host 10.2.1.87
access-list 100 deny   ip any host 10.2.1.88
access-list 100 deny   ip any host 10.2.1.89
access-list 100 deny   ip any host 10.2.1.90
access-list 100 deny   ip any host 10.2.1.91
access-list 100 deny   ip any host 10.2.1.92
access-list 100 deny   ip any host 10.2.1.93
access-list 100 deny   ip any host 10.2.1.94
access-list 100 deny   ip any host 10.2.1.95
access-list 100 deny   ip any host 10.2.1.96
access-list 100 deny   ip any host 10.2.1.97
access-list 100 deny   ip any host 10.2.1.98
access-list 100 deny   ip any host 10.2.1.99
access-list 100 deny   ip any host 10.2.1.100
access-list 100 deny   ip any host 10.3.1.1
access-list 100 deny   ip any host 10.3.1.2
access-list 100 deny   ip any host 10.3.1.3
access-list 100 deny   ip any host 10.3.1.4
access-list 100 deny   ip any host 10.3.1.5
access-list 100 deny   ip any host 10.3.1.6
access-list 100 deny   ip any host 10.3.1.7
access-list 100 deny   ip any host 10.3.1.8
access-list 100 deny   ip any host 10.3.1.9
access-list 100 deny   ip any host 10.3.1.10
access-list 100 deny   ip any host 10.3.1.11
access-list 100 deny   ip any host 10.3.1.12
access-list 100 deny   ip any host 10.3.1.13
access-list 100 deny   ip any host 10.3.1.14
access-list 100 deny   ip any host 10.3.1.15
access-list 100 deny   ip any host 10.3.1.16
access-list 100 deny   ip any host 10.3.1.17
access-list 100 deny   ip any host 10.3.1.18
access-list 100 deny   ip any host 10.3.1.19
access-list 100 deny   ip any host 10.3.1.20
access-list 100 deny   ip any host 10.3.1.21
access-list 100 deny   ip any host 10.3.1.22
access-list 100 deny   ip any host 10.3.1.23
access-list 100 deny   ip any host 10.3.1.24
access-list 100 deny   ip any host 10.3.1.25
access-list 100 deny   ip any host 10.3.1.26
access-list 100 deny   ip any host 10.3.1.27
access-list 100 deny   ip any host 10.3.1.28
access-list 100 deny   ip any host 10.3.1.29
access-list 100 deny   ip any host 10.3.1.30
access-list 100 deny   ip any host 10.3.1.31
access-list 100 deny   ip any host 10.3.1.32
access-list 100 deny   ip any host 10.3.1.33
access-list 100 deny   ip any host 10.3.1.34
access-list 100 deny   ip any host 10.3.1.35
access-list 100 deny   ip any host 10.3.1.36
access-list 100 deny   ip any host 10.3.1.37
access-list 100 deny   ip any host 10.3.1.38
access-list 100 deny   ip any host 10.3.1.39
access-list 100 deny   ip any host 10.3.1.40
access-list 100 deny   ip any host 10.3.1.41
access-list 100 deny   ip any host 10.3.1.42
access-list 100 deny   ip any host 10.3.1.43
access-list 100 deny   ip any host 10.3.1.44
access-list 100 deny   ip any host 10.3.1.45
access-list 100 deny   ip any host 10.3.1.46
access-list 100 deny   ip any host 10.3.1.47
access-list 100 deny   ip any host 10.3.1.48
access-list 100 deny   ip any host 10.3.1.49
access-list 100 deny   ip any host 10.3.1.50
access-list 100 deny   ip any host 10.3.1.51
access-list 100 deny   ip any host 10.3.1.52
access-list 100 deny   ip any host 10.3.1.53
access-list 100 deny   ip any host 10.3.1.54
access-list 100 deny   ip any host 10.3.1.55
access-list 100 deny   ip any host 10.3.1.56
access-list 100 deny   ip any host 10.3.1.57
access-list 100 deny   ip any host 10.3.1.58
access-list 100 deny   ip any host 10.3.1.59
access-list 100 deny   ip any host 10.3.1.60
access-list 100 deny   ip any host 10.3.1.61
access-list 100 deny   ip any host 10.3.1.62
access-list 100 deny   ip any host 10.3.1.63
access-list 100 deny   ip any host 10.3.1.64
access-list 100 deny   ip any host 10.3.1.65
access-list 100 deny   ip any host 10.3.1.66
access-list 100 deny   ip any host 10.3.1.67
access-list 100 deny   ip any host 10.3.1.68
access-list 100 deny   ip any host 10.3.1.69
access-list 100 deny   ip any host 10.3.1.70
access-list 100 deny   ip any host 10.3.1.71
access-list 100 deny   ip any host 10.3.1.72
access-list 100 deny   ip any host 10.3.1.73
access-list 100 deny   ip any host 10.3.1.74
access-list 100 deny   ip any host 10.3.1.75
access-list 100 deny   ip any host 10.3.1.76
access-list 100 deny   ip any host 10.3.1.77
access-list 100 deny   ip any host 10.3.1.78
access-list 100 deny   ip any host 10.3.1.79
access-list 100 deny   ip any host 10.3.1.80
access-list 100 deny   ip any host 10.3.1.81
access-list 100 deny   ip any host 10.3.1.82
access-list 100 deny   ip any host 10.3.1.83
access-list 100 deny   ip any host 10.3.1.84
access-list 100 deny   ip any host 10.3.1.85
access-list 100 deny   ip any host 10.3.1.86
access-list 100 deny   ip any host 10.3.1.87
access-list 100 deny   ip any host 10.3.1.88
access-list 100 deny   ip any host 10.3.1.89
access-list 100 deny   ip any host 10.3.1.90
access-list 100 deny   ip any host 10.3.1.91
access-list 100 deny   ip any host 10.3.1.92
access-list 100 deny   ip any host 10.3.1.93
access-list 100 deny   ip any host 10.3.1.94
access-list 100 deny   ip any host 10.3.1.95
access-list 100 deny   ip any host 10.3.1.96
access-list 100 deny   ip any host 10.3.1.97
access-list 100 deny   ip any host 10.3.1.98
access-list 100 deny   ip any host 10.3.1.99
access-list 100 deny   ip any host 10.3.1.100
access-list 100 remark NAT everything else
access-list 100 permit ip 10.1.9.0 0.0.0.255 any
access-list 105 remark CCP_ACL Category=2
access-list 105 permit ip 10.0.0.0 0.255.255.255 any
access-list 110 deny   ip 10.1.9.0 0.0.0.255 10.1.10.0 0.0.0.255
access-list 120 permit ip 10.1.9.0 0.0.0.255 10.1.10.0 0.0.0.255
access-list 150 remark Permit traffic between here and remote LAN via IPSEC
access-list 150 permit ip 10.1.9.0 0.0.0.255 10.1.10.0 0.0.0.255
access-list 151 remark ACL for VPN Client Split Tunneling
access-list 151 permit ip 10.1.9.0 0.0.0.255 any
no cdp run
route-map nonat-vpn permit 1
match ip address 100
route-map SSL-REDIRECT permit 10
match ip address SSL
match interface FastEthernet0/0/0
set ip next-hop 2.2.2.1
radius-server host 10.1.9.254 auth-port 1645 acct-port 1646 key key
control-plane
line con 0
line aux 0
line vty 0 4
privilege level 15
transport input ssh
line vty 5 15
privilege level 15
transport input ssh
scheduler allocate 20000 1000
webvpn gateway WebVPNGateway
ip address 2.2.2.2 port 443
ssl encryption 3des-sha1
ssl trustpoint TP-self-signed-1234
inservice
webvpn install svc flash0:/webvpn/svc.pkg sequence 1
webvpn context Default_context
ssl authenticate verify all
nbns-list "Windows_Servers"
   nbns-server 10.1.9.254 master
port-forward "WebVPN_Ports"
   local-port 3001 remote-server "10.1.9.254" remote-port 2029 description "MSSQLPROFXENGAGEMENT"
   local-port 3002 remote-server "10.1.9.254" remote-port 6735 description "PFXEngDesktopService"
   local-port 3003 remote-server "10.1.9.254" remote-port 6736 description "PFXSYNPFTService"
   local-port 3004 remote-server "10.1.9.254" remote-port 1434 description "SQL Listening Service"
policy group WebVPN_Policy
   functions file-access
   functions file-browse
   functions file-entry
   functions svc-required
   svc address-pool "webvpn_users"
   svc default-domain "domain.com"
   svc keep-client-installed
   svc dpd-interval gateway 30
   svc rekey method new-tunnel
   svc split include 10.1.9.0 255.255.255.0
   svc dns-server primary 10.1.9.254
   svc wins-server primary 10.1.9.254
default-group-policy WebVPN_Policy
aaa authentication list external-vpn-users
inservice
end
