Dual WAN same ISP.
Hi ,
I have 2 ADSL line with static IP from same ISP , when I active the 2nd dialer , I lose the access Internet or one
dialer only can access to the internet , I think the 2 static IP 218.189.169.1xx and 218.189.169.2xx connected to the same
gateway on ISP side as I see on IP route command 194.234.211.240 connected direct to dialer0 and connected direct to dialer1
here example of my config.
track 10 ip sla 1 reachability
delay down 5 up 5
track 20 ip sla 2 reachability
delay down 5 up 5
interface Dialer0
description *** ADSL 1 WAN Dialer ***
ip address negotiated
no ip redirects
no ip proxy-arp
ip mtu 1492
ip flow ingress
ip nat outside
ip virtual-reassembly in
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
fair-queue 64 16 2
ppp authentication pap callin
ppp chap hostname xxxxx@orange-net
ppp chap password xxxxxx
ppp pap sent-username xxxxx@orange-net password xxxxxx
ppp ipcp route default
no cdp enable
crypto map marwan
service-policy output WEB-ACCESS
hold-queue 224 in
ip rsvp bandwidth
interface Dialer1
description *** ADSL 2 WAN Dialer ***
no ip redirects
no ip proxy-arp
ip mtu 1492
ip flow ingress
ip nat outside
encapsulation ppp
dialer pool 2
fair-queue 64 16 2
ppp chap hostname xxxx@orange-net
no cdp enable
crypto map marwan
hold-queue 224 in
ip rsvp bandwidth
ip nat inside source route-map NAT_ACL0 interface Dialer0 overload
ip nat inside source route-map NAT_ACL1 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer0 track 10
ip route 0.0.0.0 0.0.0.0 Dialer1 10 track 20
ip sla 1
icmp-echo 213.186.169.2xx source-interface Dialer0
threshold 2
timeout 1000
frequency 3
ip sla schedule 1 life forever start-time now
ip sla 2
icmp-echo 213.186.169.1xx source-interface Dialer1
threshold 2
timeout 1000
frequency 3
route-map NAT_ACL0 permit 10
match ip address NAT_ACL
match interface Dialer0
route-map NAT_ACL1 permit 10
match interface Dialer1
Best Regards
Marwan Urabi
Dual WAN same ISP.
any help or suggestion !
Re:Dual WAN same ISP.
Can you post the output of show ip interface and show ip route?
Mike
Sent from Cisco Technical Support Android App
Thanks for your reply,
pls find details of ip route and ip int br
Router#sh ip route
Gateway of last resort is 194.165.130.240 to network 0.0.0.0
S*    0.0.0.0/0 [1/0] via 194.165.130.240
                is directly connected, Dialer0
                is directly connected, Dialer1
      10.0.0.0/8 is variably subnetted, 29 subnets, 2 masks
C        10.0.0.0/24 is directly connected, FastEthernet0/0
L        10.0.0.244/32 is directly connected, FastEthernet0/0
C        10.0.2.0/24 is directly connected, FastEthernet0/0.2
L        10.0.2.244/32 is directly connected, FastEthernet0/0.2
C        10.0.3.0/24 is directly connected, FastEthernet0/0.3
L        10.0.3.244/32 is directly connected, FastEthernet0/0.3
C        10.0.4.0/24 is directly connected, FastEthernet0/0.4
L        10.0.4.244/32 is directly connected, FastEthernet0/0.4
C        10.0.5.0/24 is directly connected, FastEthernet0/0.5
L        10.0.5.244/32 is directly connected, FastEthernet0/0.5
C        10.0.6.0/24 is directly connected, FastEthernet0/0.6
L        10.0.6.244/32 is directly connected, FastEthernet0/0.6
C        10.0.9.0/24 is directly connected, Loopback9
L        10.0.9.254/32 is directly connected, Loopback9
D        10.2.0.0/24 [90/2818560] via 10.123.0.2, 03:06:45, Tunnel10
D        10.2.2.0/24 [90/2818560] via 10.123.0.2, 03:06:45, Tunnel10
D        10.2.3.0/24 [90/2818560] via 10.123.0.2, 03:06:45, Tunnel10
D        10.2.4.0/24 [90/2818560] via 10.123.0.2, 03:06:45, Tunnel10
D        10.2.5.0/24 [90/2818560] via 10.123.0.2, 03:06:45, Tunnel10
D        10.2.6.0/24 [90/2818560] via 10.123.0.2, 03:06:45, Tunnel10
D        10.2.9.0/24 [90/2944000] via 10.123.0.2, 03:06:45, Tunnel10
D        10.4.0.0/24 [90/2818560] via 10.123.0.4, 13:32:14, Tunnel10
D        10.5.0.0/24 [90/28697600] via 10.123.0.5, 00:00:34, Tunnel10
D        10.6.0.0/24 [90/3100160] via 10.123.0.6, 00:00:34, Tunnel10
D        10.8.0.0/24 [90/3100160] via 10.123.0.8, 00:00:17, Tunnel10
D        10.40.0.0/24 [90/28416000] via 10.123.0.40, 18:56:45, Tunnel10
D        10.44.0.0/24 [90/28416000] via 10.123.0.44, 14:10:57, Tunnel10
C        10.123.0.0/24 is directly connected, Tunnel10
L        10.123.0.1/32 is directly connected, Tunnel10
      194.165.130.0/32 is subnetted, 1 subnets
C        194.165.130.240 is directly connected, Dialer1
      213.186.169.0/32 is subnetted, 2 subnets
C        213.186.169.1xx is directly connected, Dialer1
C        213.186.169.2xx is directly connected, Dialer0
Router#sh ip int br
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0/0            10.0.0.244      YES NVRAM  up                    up
FastEthernet0/0.2          10.0.2.244      YES NVRAM  up                    up
FastEthernet0/0.3          10.0.3.244      YES NVRAM  up                    up
FastEthernet0/1            unassigned      YES NVRAM  administratively down down
ATM0/1/0                   unassigned      YES unset  up                    up
ATM0/1/0.1                 unassigned      YES unset  up                    up
ATM0/2/0                   unassigned      YES NVRAM  up                    up
ATM0/2/0.1                 unassigned      YES unset  up                    up
FastEthernet0/3/0          unassigned      YES unset  up                    down
FastEthernet0/3/1          unassigned      YES unset  administratively down down
FastEthernet0/3/2          unassigned      YES unset  up                    down
FastEthernet0/3/3          unassigned      YES unset  up                    down
Dialer0                    213.186.169.2xx YES IPCP   up                    up
Dialer1                    213.186.169.1xx YES IPCP   up                    up
Loopback0                  unassigned      YES unset  up                    up
Loopback1                  unassigned      YES unset  up                    up
Loopback9                  10.0.9.254      YES NVRAM  up                    up
NVI0                       10.0.0.244      YES unset  up                    up
Tunnel10                   10.123.0.1      YES NVRAM  up                    up
Virtual-Access1            unassigned      YES unset  down                  down
Virtual-Access2            unassigned      YES unset  up                    up
Virtual-Access3            unassigned      YES unset  up                    up
Virtual-Access4            unassigned      YES unset  up                    up
Virtual-Template1          10.0.3.244      YES unset  up                    down
Virtual-Template9          10.0.9.254      YES unset  down                  down
Vlan1                      unassigned      YES unset  up                    down
733
