duplex mismatch
I have an ASA 5510 with a FE auto auto. The other side is 6509 GE auto auto. It turned out the link is settled at 100/half. Any ideas?
Re: duplex mismatch
Chane your port on the 6509 to full duplex. Duplexing is a "best guess" based on speed, but I don't believe it can actually autosense it.
HTH,
John
HTH, John *** Please rate all useful posts ***
Re: duplex mismatch
tried with 6509, still 100/half until both sides hard code to 100/full.
Re: duplex mismatch
It's always recommended to hard code both sides anyway, so you should be good =)
HTH,
John
Re: duplex mismatch
1. Check your cabling, it should be straight. Check/test the quality.
2. Hardcode both device to 100Mbps/Full-duplex.
3. Monitor both device interface for any errors. If there is an error, either you have a faulty/wrong cable or faulty port.
Some practice is that they connect both device while the interface is in auto/auto mode to determine which mode to hardcode them. However this doesn't work all the time because there is no standard set for auto/auto, some device although from the same vendor the auto/auto settings fails immediately or overtime causing problem to network. Most internet backbone provider hardcode the speed/duplex whenever possible. Though there are devices that cannot be hardcoded (e.g. PacketShaper GE port, HP-Unix Server port, Some Cisco Switch Model Upstream port).
140
