Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
duplex mismatch
I get this msg
duplex mismatch discovered on GigabitEthernet0/0 (not half duplex) with Switch FastEthernet1/0/46 (half duplex).
when I look @ the config , I see both side full
R1 #show run int g0/0
interface GigabitEthernet0/0
description gi0/0-chpk-sw1-fa1/0/46
ip address x.x.x.x x.x.x.x
no ip redirects
ip ospf cost 50
duplex full
speed 100
media-type rj45
no standby redirect unknown
standby 1 ip x.x.x.x
standby 1 preempt
standby 1 track Serial0/0/0
end
sw1 #show run int fa1/0/46
interface FastEthernet1/0/46
description fa0/46-R1-G0/0
switchport mode dynamic desirable
speed 100
duplex full
spanning-tree portfast
end
Re: duplex mismatch
Try leaving the speed as 100 but duplex as auto
Re: duplex mismatch
auto on both sides ?
Re: duplex mismatch
Bounce both the ports. If that does not work set both to half then back to full again.
486
