Duplicate Packet recieved between source to destination
hi,
I have a redundant network at our client.I have attached actual connectivity diagram of network. We are using Cisco 6505 switch(L3 switch) and Cisco 3750G (as a L2 switch) in network.
     I have two NIC cards at each PCs with Linux OS.We made BONDs on each PC( means two NIC cards hold one IP address which actually shows in Bond).In a PC one NIC cards works as Active and other one as a Standby.
     Its working fine when there is no change in network connectivity in network as per diagram attached.It means both active NIC cards work fine when we PING from Source PC to Destination PC.
     But if we remove Patch cord of Active Link from Source PC and try to ping from Source PC to Destination PC, every time same packet (duplicate packet) recieved from destination PC on source pc.
    My query:-
                    1) Why it is happening?
                    2) How can i resolve duplicacy of packet in this scenario?
1 REPLY
VIP Super Bronze
Re: Duplicate Packet recieved between source to destination
Hello Siddindia,
Are the 3750s stacked?  If you are connecting one NIC to one switch and the other NIC to the other switch then The NIC teaming works if the the 3750s are stacked
Reza
142
