Community Member
dynagen
Can anybody tell me , route-map future is working on dynagen sim, because as per my experiance, it only looks routing table. Please advice.
-v
Bronze
Re: dynagen
Please connect on host PC or router as source IP address,
I have already check, it is working fine
-Minu.
Re: dynagen
Vinod,
I had tested it and it does work.
I suggest you to Register to Hacki forum and post these questions there. The forum is dedicated to Dynamips and dynagen
http://hacki.at/7200emu/
Narayan
Re: dynagen
HI Narayan,
I have been long-time hearing about this Dynagen & Dynamips.
What is Dynagen ?
----is it a Simulator
Best Regards,
Guru Prasad R
Re: dynagen
Guru,
Yes it is the best simulator you can work upon.
It simulates a true router on your PC
For more information log on to this link
http://www.ipflow.utc.fr/index.php/Cisco_7200_Simulator
HTH, rate if it does
Narayan
108
