Community Member
Dynamips fa0/0 down
Friends,
Not sure if this is the right forum to post this message. But anyone using dynamips, plz help if you can.
I am using a simple config. When I load my 7200 emulator, my fa0/0 interface is showing as down with the log showing "ASSERT CRITICAL fa0/0 physical port".
My net file is as below
[[7200]]
image = [[7200]]
image = \Program Files\Dynamips\images\c7200-adventerprisek9_sna-mz.124-11.T.bin
F0/0 = NIO_gen_eth:\Device\NPF_{7D3D1C91-B590-4B15-BA1E-EA84F2F85B8B}
ram = 160
[[router R2]]
I've tried to shut and unshut the interface, use different ios version, still the same problem. Thanks
- Manoj
Silver
Re: Dynamips fa0/0 down
This document provides a general description of digital subscriber line (DSL) components and how the components fit together in a basic DSL implementation. The sample configurations in this document show the most common DSL networks that are currently in use. You can use these configurations as a general reference to design a broadband aggregation implementation. However, do not view these configurations as a cookie-cutter solution. Every customer and every requirement are different, and there are many ways to accomplish the same design goals
http://cisco.com/en/US/tech/tk175/tk15/technologies_configuration_example09186a0080093e43.shtml
Community Member
manoj pls let us know comple net file configuration.
seems its not connected to any device in ur config.
but anyhow u still want ur ethernet to remain uop without connectivity so that you can practice routing you can use below command under interface configuration mode
no keep
168
