E1 enable
I installed 1 2MFT VWIC card in 2821 router if I command sh ver I see this card detect but sh run command I can?t see it any controller how can I enable it for E1 configuration
robin
Re: E1 enable
Hi Robin
Can you post the output of show version here ?
Also have you tried configuring card type e1 ?
regds
Re: E1 enable
Hi friend,
I think you are using a version 2 card.
In this case you require the following command
(config)#card type e1/t1
eg. card type e1 0 1
HTH, rate if it does
Narayan
128
