Community Member
e1 is not responding
Dear,
I have MWR1941 router . This router has VWIC-2MFT-E1DIR. It has a default y cable configuration. My problem is associated with e1 . MY card is not sending any singnal. Please advise.Pls check the sh controller and sh run
Re: e1 is not responding
The controller shows loss of frame.
Make sure the framing matches at both ends. Try chnaging it to framing no-CRC4 under the controller confguration and test
Narayan
Hall of Fame Super Gold
There are also loopbacks on the line and because this appears to be a professional installation for mobile neetwork, you probably have a maintenance department that should look into that.
Community Member
Dear Narayan,
Now I ahve no option to do your test. I am sending another attached file . pls advise.
Still loss of frame.
also saw alarm incoming signal as well. You need to check the parameters at both ends
Narayan
Community Member
Dear Narayan,
I have solved the problem yesterday night and sorry inform you. I had to reconfigure it.
Bikash
114
