E1 ISDN-PRI
It must router 3845 and I buy a card VWIC2-1MFT-T1/E1, when configure the controller (Pri-Group timeslot 1-31) leaves a message "Not enough DSP resources available", is required to have DSP so that it works like a contingency ISDN for data. The IOS is ip-voice 12.4T, thanks
Hall of Fame Super Gold
Re: E1 ISDN-PRI
Hi, load a non-voice image like ipbase and you will be able to configure PRI as for data only.
Re: E1 ISDN-PRI
It is necessary to have installed DSP.
Re: E1 ISDN-PRI
As mentioned above, when you load an image without voice support, you will be able to do data isdn pri without dsp. Else, you will need to have dsp.
Re: E1 ISDN-PRI
It is possible to be config without DSP to receive calls ISDN and to raise data by contingency from a remote ISDN-BRI.
The command ISDN TEST CALL INTERF s 0/2/0:15
and debug. the message received is:
ISDN Se0/2/0:15 **ERROR**: call_setup_ack_proceeding: NO HDLC available b channel 14 call id 0x8009
Re: E1 ISDN-PRI
I have PVDM.
Re: E1 ISDN-PRI
Which exact IOS are you running?
This is how you configure for integrated data and voice on isdn PRI:
http://www.cisco.com/en/US/docs/ios/12_4t/12_4t11/intserv.html
Note I recommend you use 12.4(11)XJ4 for that.
As a recognition to those providing answers, please rate useful posts with the scrollbox below!
226
