E1 Module for 7206
wasiimcisco
hi,
i have Cisco 7206VXR (NPE-G2). I want to terminate E1 module on that router.
Can anyone tell me which E1 moudle is supported on this plateform. I am searching the E1 module on cisco website but not getting the right one.
Please guide me.
One E1 moudle is installed on my 3825
VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1
will that moudule support in 7206.
I am waiting for reply
paolo bevilacqua
7200 and 2800/3800 do not share any common hardware. How many E1 ports do you need? The smaller module (port adapter) for the 7200 is PA-MC-2E1. Then there are 8 ports modules.
Thanks for the reply,
Can u please tell me is there any module that provide me Rj48 interface for E1. Because i am using 3825 with
that provide me RJ48. I wana have the same sort of module that provide 7206 with RJ48.
I am looking at cisco site but still not able to get it.
Yes, all are RJ48 interfaces. If you browse in the technical information for "port adapters" you will see them.
Thanks for the rating and good luck!
