E1 PRI configuration Help
resfat2001
Can you please send me a configuration for an E1 PRI , i will use this access for data transfer.
thanks
5 Replies 5
resfat2001
can I use this configuration ?
controller E1 1/0
framing NO-CRC4
pri-group timeslots 1-31
interface Serial1/0:15
ip address 192.168.150.34 255.255.255.224
no cdp enable
encapsulation ppp
dialer idle-timeout 119
dialer string xxxxxx
dialer-group 1
isdn switch-type primary-net5
isdn point-to-point-setup
ppp authentication chap pap callin
ppp chap hostname yyyyyyyy
ppp chap password zzzzzz
dialer-list 1 protocol ip permit
resfat2001
can use this configuration?
Thnaks
controller E1 1/0
framing NO-CRC4
no cdp enable
encapsulation ppp
dialer-group 1
Hi there,
Your configuration basically seems fine, what is the scenario that you are trying to fulfill ?
BR,
Mohammed Mahmoud.
I want to use this PRI to backup an access 2Mbps in ser0/0, if it will be down.
what the command isdn point-to-point-setup
mean please?
If you wanna use it as a backup link, try using with Static Routes with higher Admin Distance or try with Backup Interface.
If you want I may post the configs also.
