E1 timing issue
I have an issue with slip secs on a 2811 with a VWIC-1MFT-E1 card, I have tried setting the clock source to internal as well as line but this issue remains, any ideas? thanks
E1 0/0/0 is up.
Applique type is Channelized E1 - balanced
No alarms detected.
alarm-trigger is not set
Version info Firmware: 20041023, FPGA: 16, spm_count = 0
Framing is CRC4, Line Code is HDB3, Clock Source is Internal.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (574 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
14 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
14 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 24 hours)
0 Line Code Violations, 0 Path Code Violations,
2530 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
2530 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
VIP Purple
Re: E1 timing issue
since slip secs are almost always clocking-related, and since you already have tested the only configurable options on your end, line and internal, I would check with the service provider and have them run a test to their DSU/CSU.
GP
Re: E1 timing issue
I had a similiar issue with a T1 on a 2821. I added the "network-clock-select 1 t1 0/0/0" referencing my T1 controller and my slips went away. This is a global config command and it tells the backplane to derive clock from the controller you specify. You can do a 'show network-clocks' command to see what the current clock source is. By default it is the backplane.
Jason
Re: E1 timing issue
140
