Bronze
E1 up serial protocol down
Hi guys, I have a problem with a configuration, I have a C3745, a E1 card used before and a new 12 Digital Modems. I need to configure these Digital modules but if I configure the serial X/X:15 with a ppp encapsulation, the serial protocol goes down!!!!, on the other hand if I configure the hdlc encapsulation, serial is OK. Some help, do i need to talk with my service provider about this?
Thanks a lot guys
David
Hall of Fame Super Gold
Re: E1 up serial protocol down
1st, which E1 card do you have ? Check show diag to know.
2nd, which Digital modems do you have? Again, show diag will tell you.
3nd, unless you receive digital calls, encapsulation on serial doesn't matter. You want PPP on group-async that controls the modems.
Bronze
Hi Paolo, thanks for your mail,
1. High Density Voice NM-HDV2-1T1/E1 Port adapter
2- Digital Modems Port adapter, 12 ports
3. A have 10 remote users that need that they dial into my network.
I have these relevant configuration.
controller E1 2/0
pri-group timeslots 1-31
interface Serial2/0:15
no ip address
encapsulation ppp
isdn switch-type primary-net5
isdn incoming-voice modem
isdn calling-number 2623122
interface Group-Async0
ip unnumbered GigabitEthernet0/0
encapsulation ppp
dialer in-band
dialer idle-timeout 1500
dialer-group 1
async dynamic routing
async mode dedicated
peer default ip address pool dialin
keepalive 10 3
ppp authentication pap
group-range 1/0 1/11
line 1/0 1/11
modem Dialin
modem autoconfigure type default
transport input all
autoselect during-login
autoselect ppp
autohangup
SA_RAS#sh inter s2/0:15
Serial2/0:15 is up, line protocol is down
THANKS A LOT PAOLO
David
Hi, do you have PVDM2-12DM ? please check show diag.
Then check circuit status with "show controllers E1"
Bronze
Hi Paolo, thanks again for your time, these are the show controlller/inter seri
SA_RAS#sh controllers e1
E1 2/0 is up.
Applique type is Channelized E1 - balanced
No alarms detected.
alarm-trigger is not set
Version info Firmware: 20040802, FPGA: 255, spm_count = 0
Framing is CRC4, Line Code is HDB3, Clock Source is Line.
Current port master clock:recovered from controller 2/0
Data in current interval (362 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 1 15 minute intervals):
0 Line Code Violations, 6 Path Code Violations,
1 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
1 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Hardware is DSX1
MTU 1500 bytes, BW 64 Kbit, DLY 20000 usec,
Encapsulation PPP, loopback not set
Keepalive set (10 sec)
Last input 00:00:02, output never, output hang never
Last clearing of "show interface" counters 00:06:55
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/1/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 48 kilobits/sec
184 packets input, 552 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
184 packets output, 552 bytes, 0 underruns
0 carrier transitions
THANKS AGAIN
DAVID
Send "show diag" to verify HW compatibiliy of the digital modems.
Bronze
Ok, thanks Paolo
-show diag
-show run
-show controller e1 / show inter s2/0:15
Best regards
David
Hi, you cannot use the NM-HDV2-1T1/E1 to send modem calls to the NM-30DM.
You can use only the PRI or BRI card listed in "requirements" at:
http://www.cisco.com/en/US/prod/collateral/routers/ps274/product_data_sheet09186a0080091b98.html
Also, on a 3825 the native method for modem calls is the PVDM2-xxDM hoste directly on the motherboard.
Bronze
Thanks a lot for you time Paolo,
If we can, we'll try with another NM according to the hardware requirements.
All the best
David
Bronze
Hi Paolo, finally I get a NM-PRI-2CE1U only for a test, to configure my digital modems that are in my Cisco 3825. Just one question, does the NM-PRI-2CE1U modelule will need DSP? if yes, can I use the DSP of the PVDM2-32?
Thanks again,
All the best
David
No, NM-PRI-2CE1U does not work with PVDM2-32.
Bronze
Hi Paolo, again thanks for your time, I'm going to install the NM in a few hours, this last one please, if the NM-2CE1U does not work with PVDM2, it means that this particular NM can work without PVDMs?
Thanks a lot
Best regards.
David.
926
